Old 01-02-2021, 07:07 PM   #21
rod
Liked 20 Times in 15 Posts
Default Re: Rear end Gear lube
just remember, for U guys who are running posi/trac-loks or whatever [any thing besides a spool], do NOT use synthetic lubes. same goes for brass syncro transmissions.
Rod in AZ
rod is offline   Reply With Quote
Old 01-02-2021, 08:25 PM   #22
6130
Liked 117 Times in 50 Posts
I ran ATF in the rear end of my Mazda...
Old 02-21-2021, 05:35 PM   #23
Greg Jones
My 12 Bolts have done great running Torco 85-140 with pro gears, backlash clearance makes a difference with the viscosity lubes you use also. Synthetic is more slippery and somewhat thinner than mineral based lubes, tight clearances can benefit from synthetics.
Greg Jones is offline   Reply With Quote
Old 02-24-2021, 06:46 PM   #24
Isaac Zane
Isaac Zane's Avatar
Liked 50 Times in 14 Posts
Mobil 1 Syn Gear Lube 75W-90. Great in manual transmissions as well. Works great in Harley transmissions too. 160k miles going well! Knock wood!
Isaac Zane STK 1237
J/SA Buick Apollo
Patriot Guard Rider DOOF 43
Isaac Zane is offline   Reply With Quote
Old 02-24-2021, 08:12 PM   #25
e vassar
Liked 271 Times in 107 Posts
ATF
Billy...how much?.
I guess I have to pull the cover off to make sure I get all the old lube out?
Old 04-09-2021, 10:07 PM   #26
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
GL-5 is the key ingredient to look for drag racing.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 04-09-2021, 10:16 PM   #27
Mike Rietow
GL-5 $4.97
Old 04-10-2021, 03:33 AM   #28
Dave Gantz
Liked 251 Times in 125 Posts
Hi Mike, just wondering, why?
Old 04-10-2021, 09:32 AM   #29
Rory McNeil
I`m curious as well. I had been told that the main difference between GL-4 and GL-5 gear oils, was that the GL-4 was designed for use in manual transmissions with "yellow metal" syncronizers, like brass/bronze, and the GL-5 was for syncros with paper or carbon fiber linings. It seems that finding GL-4 gear oil is not as easy these days, GL-5 seems far more common. For the Toploader 4 speed in my street car, I have been using GL-4 Brad Penn, seems most of the major oil companies have just GL-5.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 04-10-2021, 10:43 AM   #30
Mike Rietow
I run US Gear, when I asked what they like to see in gear oil, they said GL-5 is the key ingredient drag racing.
Valvoline High Performance gear oil is GL-5
Valvoline regular gear oil is not.
Here's a mention in dragzine confirming they're recommendation. No technical terms though, I couldn't find anything other than this.
I just use $4.97 Valvoline GL-5 80w 90. Ford 9" Strange chunk, I've had several different gear ratios in. 3.90, 4.10, 4.33. 4.56, 5.00, 5.29
3200 lb 23 n/a sbc 1.27 60 ft
https://www.dragzine.com/news/lubric...r-in-gear-oil/
