#21 |
Liked 20 Times in 15 Posts
just remember, for U guys who are running posi/trac-loks or whatever [any thing besides a spool], do NOT use synthetic lubes. same goes for brass syncro transmissions.
Rod in AZ |
#22 |
Liked 117 Times in 50 Posts
I ran ATF in the rear end of my Mazda...
#23 |
My 12 Bolts have done great running Torco 85-140 with pro gears, backlash clearance makes a difference with the viscosity lubes you use also. Synthetic is more slippery and somewhat thinner than mineral based lubes, tight clearances can benefit from synthetics.
#24 |
Liked 50 Times in 14 Posts
Mobil 1 Syn Gear Lube 75W-90. Great in manual transmissions as well. Works great in Harley transmissions too. 160k miles going well! Knock wood!
Isaac Zane STK 1237 J/SA Buick Apollo Patriot Guard Rider DOOF 43 |
#25 |
Liked 272 Times in 108 Posts
#26 |
Liked 30 Times in 16 Posts
GL-5 is the key ingredient to look for drag racing.
#27 |
GL-5 $4.97
#28 |
Liked 251 Times in 125 Posts
#29 |
I`m curious as well. I had been told that the main difference between GL-4 and GL-5 gear oils, was that the GL-4 was designed for use in manual transmissions with "yellow metal" syncronizers, like brass/bronze, and the GL-5 was for syncros with paper or carbon fiber linings. It seems that finding GL-4 gear oil is not as easy these days, GL-5 seems far more common. For the Toploader 4 speed in my street car, I have been using GL-4 Brad Penn, seems most of the major oil companies have just GL-5.
#30 |
I run US Gear, when I asked what they like to see in gear oil, they said GL-5 is the key ingredient drag racing.
Valvoline High Performance gear oil is GL-5 Valvoline regular gear oil is not. Here's a mention in dragzine confirming they're recommendation. No technical terms though, I couldn't find anything other than this. I just use $4.97 Valvoline GL-5 80w 90. Ford 9" Strange chunk, I've had several different gear ratios in. 3.90, 4.10, 4.33. 4.56, 5.00, 5.29 3200 lb 23 n/a sbc 1.27 60 ft https://www.dragzine.com/news/lubric...r-in-gear-oil/ Last edited by Mike Rietow; 04-10-2021 at 10:50 AM. |
