Old 03-28-2008, 07:04 PM   #1
rgarvey
Default dq
anybody know why jerry davis is on the dq list at houston?
rgarvey is offline   Reply With Quote
Old 03-28-2008, 07:09 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: dq
it just could be as simple as not passing the fuel piss test
Old 03-28-2008, 09:55 PM   #3
RJ Sledge
Liked 292 Times in 92 Posts
Default Re: dq
They tore down 3 cars, Jarrod Granier and Terry Emmons got through, heard that Jerry had a problem with cam and heads??? I guess if you attend a Divisional Race or National in Div 4 'Land" you better be right or you might be toast. It ought to be interesting at Belle Rose next week, as Mr. Roberson will be on the prowl, and Pat has lots of empty shop space with engine hoists to spare. Have already heard of a "rod and piston" that is suppose to be coming out down there, wonder who will win the lottery???
Ain't it great
Later RJ
RJ Sledge is offline   Reply With Quote
Old 03-30-2008, 01:31 PM   #4
Bruce Noland
Liked 444 Times in 145 Posts
Default Re: dq
We should have a best no name contest!
Bruce Noland 1788 STK
Old 03-30-2008, 08:29 PM   #5
Jeremy
Default Re: dq
Cam lift checked .010 safe side with my check lifter during the inspection but Bruce would only accept an NHRA lifter. They used a big block Mopar lifter which is different push rod seat which caused an increase. By the time I figured out what was going down I was gone.
5 cc's of the port volume was because of the change from the stock tulip valve to a cut down Manley nail head valve and some more for the new any valve job.
Thanks
Jerry
Jeremy is offline   Reply With Quote
Old 03-30-2008, 08:43 PM   #6
Chad Rhodes
Default Re: dq
Thanks
Jerry
how could a different pushrod seat make it move further? changed the rocker geometry i guess?
Chad Rhodes 2113 I/SA
Old 03-30-2008, 09:04 PM   #7
Liked 1,898 Times in 426 Posts
Default Re: dq
The location of the pushrod seat directly effects the effective length of the pushrod. Now, a rocker arm is NOT constant ratio. The ratio of a rocker arm changes constantly as the ends rotate around the fulcrum. Raising or lowering the pushrod seat raises or lowers the pushrod, changing the effective ratio of the rocker at various points.
Old 03-30-2008, 09:04 PM   #8
Liked 10,838 Times in 2,253 Posts
Default Re: dq
If the lifter seat is and or the lifter is taller than the one used, the adjustment screw moves closer to the fulcrum changing the lift at the valve.
On head runner cc there is no rule in stock.
Old 03-30-2008, 09:07 PM   #9
Default Re: dq
I was told by 3-4 NHRA tech guys that they are pouring Stock heads at random, and collecting data to make a database.
Old 03-30-2008, 09:22 PM   #10
Jeremy
Default Re: dq
Lifter push rods angle on a small Mopar and the Hemi's are very bad. If the correct lifter (with lots of clearance around the push rod)is not used the pushrod will hit the side of the push rod seat and cause the push rod to raise off of it's seat which will increase the lift.
