Liked 10,756 Times in 2,236 Posts
Car#-Driver(Opp'nt)-RT-----ET-- Speed-----Car#-Driver(Opp'nt)-RT-----ET-- Speed
32 Doug Duel 2124 Jeff Strickland E1 ****WINNER**** 0.054 10.507 124.41 0.032 9.415 129.58 C/SA Dial: 10.50 (+/-): 0.007 FS/B Dial: 10.50 (+/-): -1.085 Qualified: #6 10.447 -0.953 #35 9.354 -0.646 Strickland with the starting line advantage, but took too much stripe to give Duel the win. Strickland gets dialed .50 of a second over the FS/B index of 10.00. NHRA will not let a racer dial above the Index. |
Liked 534 Times in 143 Posts
Looks like a bad dial to me. He probably dialed a 9.50, but the tower fat fingered a 10.50. He might have not checked the board before staging and accepted it.
Liked 7,779 Times in 1,742 Posts
DRC misprint?
Nobody is going to take a second of win light. Especially somebody like Strickland.
I thought NHRA had a program that would not allow a dial above the class index.
Liked 228 Times in 70 Posts
This is very common. Any time the dial in is incorrect initially it doesn’t always get corrected on the results.
#6 | |
Liked 795 Times in 210 Posts
Should’ve had Foley at 10.90 not 10.40.
"Pistol" Pete Dutko |
What the other Cooter said happened on this run as a matter of fact Foley was about to stage when he noticed his was wrong and they changed it.
Liked 48 Times in 22 Posts
I watched this on NHRA.TV live and it was actually 9.38 dial for Strickland and the handicapped start happened. I remember is was pretty close but didn't do the math to see if it was right that way or not.
Liked 34 Times in 6 Posts
I did my burnout, went through my routine and always check the boards before I roll into prestige. I looked and 10.40. I pointed to starter and they changed it.
Thanks
