Liked 1,002 Times in 203 Posts
Looking for some 1/4 inch gasket material to make some carb base gaskets for my wcfb carbs. Must be at least 5 inches by 6 1/2 inches. thanks Pm me or 815 8four 8 5zero 20
#2 | |
One source for the material sheet is Accurate Felt & Gasket. You need Nitrile Butadiene material and see if the have it with a steel core. They may suggest something that will work also. They make lots of the gasket material for the aftermarket. You can call them and explain what you need and they may even send you a free sample. https://www.afgco.com/fibre-cellulose |
