Liked 3,173 Times in 971 Posts
This topic has bled over to a couple of unrelated threads so here goes. Recently upgraded to enclosed aluminum trailer and DO NOT want to see all that aluminum messed up by a tire failure or change a tire on a narrow shoulder off I-75 (been there, done that). It would seem these are the leading candidates but inviting endorsements and recommendations including insight on the flow-thru sensors and need for a booster.
https://eezrvproducts.com/ https://tsttruck.com/ Thanks in advance...
Liked 2 Times in 1 Post
Jim: I just ordered a TST one on Friday & I wanted to set it up to see how it worked. I check with some of the full time rv's to see what they thought & they liked it because of the screen & size. I've got a tri axle trailer & I used the out side tires on the screen but I would read ALL instruction first so you will understand. If you go this route the TST Truck web suite go to the bottom & click on faq's & look at all the videos. I got this model, TST-507-RC-6. Which is the colour screen with 6 pressure caps. Not the flow through . The unit comes with battery's in the caps & all charged up . I got my from Amazon but there's a dealer down your way called. Techno RV which is same price but they are there if you have any problems setting it up. I hope this helps. Bill
#3 | |
Liked 800 Times in 337 Posts
Pressure Pro https://pressurepro.us/ |
Liked 1,877 Times in 577 Posts
I decided on the https://innovationtire.com/product/t...-and-trailers/. 10 sensors. With a coupon code of endlessrving20 saves $20. So under $400.
Liked 100 Times in 51 Posts
I've had the EEZRV system on my trailers for over 5 years. It just saved me from a blowout coming back from GA on Saturday morning. I picked up a small oblect that caused a slow leak. The alarm went off at my preset low pressure warning. Got the tire fixed and continued on with the same tire. BTW, since having this system, it has saved me on three other occasions also. The peace-of-mind while traveling is very nice. Along with my AFG Fireballs, I travel much easier.
Hit me up if you would like more info about the Fireballs. Dan SC 4698
Dan Foley SC 4698 |
What is an AFG Fireball??
Think Dan is referring to the mini fire extinguishers...he can correct me if he’s pointing elsewhere.
Thanks for the TPMS suggestions. I’ll study the options, now on to selecting a GPS tracker to hide in the trailer. I HATE thieves!
#8 | |
that also is on my list of goodies
#10 | |
I’ve used this one for over 4 years. No subscription, just buy a SIM card. https://www.ebay.com/itm/Coban-track...-/401450362456
Dan Foley SC 4698 |
