Old 05-04-2021, 03:53 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Bad Shock
Is it possible for a car with leaf springs,Cal-Tracs and stock shocks to pull to one side under acceleration of one of your shocks is bad?
jaf2021 is offline   Reply With Quote
Old 05-04-2021, 05:33 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: Bad Shock
I guess its possible but I would be looking at other things first. Check to see if the rear is square in the car. would be the first thing I would check. While you are under there you can loosen the bottom of the shocks and run them through the stroke to see if they feel like anything is going on with them. Check the adjustment on the bars to see if they are neutral. I would also give Caltracks a call to see what they have to say.
Mike Pearson 2485 SS
Old 05-04-2021, 05:34 PM   #3
Jeff Stout
Liked 706 Times in 283 Posts
Make sure housing is on spring perches correctly. Also brackets on spring eyes could be flexing or cracked welds.
Old 05-04-2021, 11:40 PM   #4
CMcAllister
Liked 920 Times in 259 Posts
Scales will help diagnose what is going on. Especially if the car had previously been baselined, numbers recorded, worked ok, and is now misbehaving.
Even if this wasn't done, corner weights are useful.
Bad shocks will make a car do stupid things. As stated, a good visual inspection is the first step.
CMcAllister is online now   Reply With Quote
Old 05-05-2021, 02:17 AM   #5
GTX JOHN
All the Above.
Also check everything for tightness and condition
of all suspension stuff.
John Irving
741 Stock
741 Super Stock
Old 05-05-2021, 09:14 AM   #6
Jody Lang
Liked 89 Times in 28 Posts
First thing I would check is rear tire diameter to see if they’re the same.
Jody Lang is offline   Reply With Quote
Old 05-05-2021, 09:40 AM   #7
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
what type of leaf spring also check your settings on bars, could of tighten or loosen up, this would cause it to pull.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 05-05-2021, 12:58 PM   #8
340Cuda
Liked 805 Times in 341 Posts
I had a similar problem with a car with Cal-Tracks, mono leafs and Rancho shocks.
Chased a lot of things including taking it to the chassis shop and correcting some minor things.
It turned out it was a bad slick. M/T Radial, old but with not that many runs.
So you might try a different pair of tires if you have not done so already.
Old 05-05-2021, 01:08 PM   #9
jaf2021
Hey 340Cuda I do have some M/T radials that are old with about 20 passes on the car right now
Old 05-05-2021, 01:24 PM   #10
340Cuda
That sure could be it.
I have never heard of anyone else having this problem but I would sure try changing them out.
