Old 04-19-2021, 02:54 PM   #21
383bigblock
Default Re: Stock 1975 Dodge Coronet. Mopar guys.
Who are the go-to guys for engine machining, transmission building, etc?
383bigblock is offline   Reply With Quote
Old 04-20-2021, 04:41 AM   #22
GTX JOHN
Liked 2,490 Times in 700 Posts
Originally Posted by 383bigblock View Post
Thank you for the replies. West coast guy here. Who are the mopar guys to deal with for engine machining/building? Ive heard different names over the years just not sure who is still around for stock engine builds. 727 OR 904 behind a 400ci stocker? 8 3/4 or dana? Thank you.
Our 400 Mopar short blocks was built by Gregg Luneauk at Tri City
Performance in Vista Cal. It is 1 Second ++ when we need it to be!
Must run 727 as 904 will not bolt in without Illegal Adapter.
Pro Trans in Waco Texas did the Transmission.
We break a lot of very good 8 3/4 in that heavy a car. 73 Roadrunner @ 3800 Lbs
John Irving
741 Stock
741 Super Stock
Old 05-04-2021, 02:11 PM   #23
383bigblock
Thanks for all the replies. John what rear gear do you run?
Old 05-05-2021, 02:11 AM   #24
GTX JOHN
Believe it or not: 4.56 Dana with 94 Cir Goodyear Radial
Shift @ 5900 to 6000 RPM
Not a High RPM Combo!
Gregg Luneauk does our Short Block
Brad Van Lant does our heads
John Irving
741 Stock
741 Super Stock
Old 05-24-2021, 01:01 PM   #25
383bigblock
Would a 383 block bored .060 over be legal.
Old 05-24-2021, 05:04 PM   #26
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Yes, for a 383.
Old 05-24-2021, 06:37 PM   #27
Frank Castros
Liked 2,755 Times in 975 Posts
You might want to think about a filled 400 block as well.
Old 05-24-2021, 11:15 PM   #28
BigBlockBill
Liked 98 Times in 31 Posts
What's the RPMs through the traps?????
BigBlockBill is offline   Reply With Quote
Old 05-25-2021, 12:08 PM   #29
GTX JOHN
6600 @ 119
John Irving
741 Stock
741 Super Stock
Old 05-27-2021, 10:49 AM   #30
Liked 10,902 Times in 2,255 Posts
A dana 60 for the back. Before you machine or choose an engine combination look at ring availability. The 360 with the factory 4.00" bore will have a better selection of piston rings than the 4.340 bore of the 400. Dont forget to look at rod selection on the approved list and if they are available.
Just some thoughts.
