Old 06-03-2021, 08:24 PM   #1
L.Fite
Liked 497 Times in 243 Posts
Question Rear gear selection...
So... what gear ratio is common on 396 or 427 combos?
From past experience I'm guessing 4.88 or 5.13?
Would that be in the ballpark?
How tight do those things turn? (in a stocker?)
7000? 7500?
MPH 130ish?
L.Fite is offline   Reply With Quote
Old 06-04-2021, 06:20 AM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Rear gear selection...
A lot of factors to consider. Oval or Rec port? Weight of car? HP rated and dynod? 1/4 or 1/8 racing.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 06-04-2021, 07:44 AM   #3
nhramnl
Liked 358 Times in 83 Posts
What Terry said...
Old 06-04-2021, 08:11 AM   #4
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
Tire diameter should be considered as well. Radial or bias ply will play into the equation too.
Ernie Neal
SS 354
Old 06-04-2021, 08:53 AM   #5
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Back in 1992 I went 10.54 at 123 mph with a 5.13 at the Snowbird Nationals 29.5 Firestone slick crossing 7600 rpm.
Nothing burger cast crank BBC 427 600 lift flat tap, steel Merlin heads 3475 all steel Nova
That was flying in 1992 home built on $10.00 bucks an hour.
I'd put a 5.13 in it. I learned the easy way in 92, the first 100 ft makes you.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 06-04-2021, 10:08 AM   #6
Bobby Lundholm
Liked 127 Times in 49 Posts
Wasn't the 5.00 gear created for these combos?
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 06-04-2021, 11:33 AM   #7
Ralph A Powell
Liked 225 Times in 136 Posts
When I at Ford they were making 5.20s and 5.00 cause the 5.14 gear is a week design because of the tooth count.
Ralph A Powell is online now   Reply With Quote
Old 06-04-2021, 05:27 PM   #8
L.Fite
Aren't those (5.00 gears) hard to find for a 12 bolt?
Old 06-04-2021, 05:44 PM   #9
L.Fite
Just generally speaking...
Square port stuff... A/S, B/S, etc.
Looking at some of the heads up races, can't tell how hard they are running these things, just got me curious.
Putting a car together and trying to decide what I want to do with it...
Long way to go yet...
Old 06-04-2021, 08:39 PM   #10
L.Fite
Thanks.
