#11 |
Liked 695 Times in 206 Posts
I have used both ATI and regular Type F. Never saw a difference. I would like to think that the ATI would hold up better to heat. I don’t run a trans cooler even though I should.
#12 |
Liked 70 Times in 31 Posts
Wow. I changed mine last year after a couple years and probably 100 plus runs and felt like I wasted my money.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#13 |
Liked 49 Times in 22 Posts
Steven Barnes Stock 704 N/SA |
#14 |
Liked 186 Times in 55 Posts
#15 |
Liked 2,516 Times in 701 Posts
We run Walmart Type F in all our Torqueflites that
have every trick piece = Change ever 25 runs (Cheap Ins.)
#16 |
Liked 10,963 Times in 2,260 Posts
Protrans Joel's on Joy
#17 |
Liked 19 Times in 9 Posts
Thanks for the feedback on this subject, always learn something here. Thanks! I'm putting a car back together and used to use Amsoil in my 904's with aluminum pieces. I just wanted to see what others thought.
George Mirza I still have the trick Thermoquad items you made for me many years ago, and will continue to use them! |
#18 |
Liked 30 Times in 12 Posts
Torco.
#19 |
Liked 51 Times in 30 Posts
the Kevlar bands wear the aluminum drums, turned fluid gray, had to change fluid every race, switched to red band, with trans brake, reaction times went up as fluid turned grayer
#20 |
Liked 265 Times in 69 Posts
I have had good luck with ATF4 synthetic fluid.
John Dinkel 3295 STK |
