Liked 54 Times in 33 Posts
Seeking help on inspecting an early Jericho. Get it ready for racing.
Thanks Bruce 909 844 ten eighty one |
Doesn't anyone run a Jericho in Stock or S/S So. Cal.?
Liked 1,590 Times in 583 Posts
Liked 210 Times in 88 Posts
Does anyone in So Cal run a stick????
Phil Vos |
There are a few, and I will be one. Thanks for all of the direct positive responeses.
Bruce, Don Keen probably knows a bit about that trans. I don't know if he does any side work.
Dennis Alvey knows them inside out, over here in Az. Again, I don't know if he would want to be involved..He stays pretty busy. Looking forward to seeing this new piece. :-)
#8 | |
Liked 1,436 Times in 299 Posts
Call Jerico and find out what version it is. That will determine if it is a narrow gear or wide or what it is. Take the covers off and count the teeth. Compare it to the gear ratio chart on Jerico’s web site Look at general condition. Roll it over in each gear to feel for tight spots. Look at dog rings and sliders. Beyond that it really needs disassembly to check it out. If it is a narrow gear, it isn’t worth buying unless it has the ratios you need, is in good condition and in a low power light weight car. You can’t get many parts for the narrow gear. Older wide gear is possible to order some parts. Buy some good quality snap rings pliers and read the manual that is also on line. Pretty easy to work on.
James Schaechter 3163 STK |
#9 | |
Liked 52 Times in 22 Posts
Roderick Racing had a Jerico recently listed for sale on Class Racer. He is from California. Maybe he is a "guru".
