Old 08-29-2021, 02:37 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Head gasket sealant
What's folks using for head gasket sealant? Never had any issues with leaking until recently. Had water in #2 and yesterday discovered #1 and #2 bubbling thru radiator. Same block and heads. Fixed water in cylinder, ran a couple races and now found bubbling. No water loss. Used shim gaskets with spray copper coat. Have been using it for years. Same process, clean surfaces, spray copper coat, torque accordingly. Has anyone had issues with copper coat?
Ed McLawhorn Jr. is offline   Reply With Quote
Old 08-29-2021, 03:21 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Head gasket sealant
We always used either Hylomar or Aluminum spray paint --with hylomar spray one coat on both sides let set for a few minutes (1-2) then install---with Alum paint spray both sides 3-4 light coats let dry til almost dry (3-4minutes) then install---- check both the block and head surfaces AND both sides of the gasket in that area for any SMALL scratches, nicks etc. that might be causing the problem too-FED 387
Old 08-29-2021, 04:14 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Are they new shim gaskets or reused gaskets with copper coat ?
Old 08-29-2021, 06:14 PM   #4
Ed McLawhorn Jr.
They were new shims in the sense they never been used. They were old though...had been on the shelf for years. Wondering if they are not collapsing and sealing the raised edge on gasket?
I remember dad using aluminum paint sometimes too when he didn't have copper coat. Seemed to work pretty well too.
Old 08-29-2021, 11:05 PM   #5
Jeff Stout
Liked 704 Times in 281 Posts
Copper coat has worked well for me. 12 to 1 and 175 HP nitrous. No problems
Old 08-30-2021, 11:56 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,930 Times in 580 Posts
Sounds like you need to check the deck and head surfaces to make sure they are flat. Typically copper coat and shim gaskets is a good combo if everything is smooth and flat.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 08-30-2021, 12:12 PM   #7
Blackgar
Liked 48 Times in 18 Posts
VHT copper spray is better than all of the others
Blackgar is offline   Reply With Quote
Old 08-30-2021, 12:58 PM   #8
Ralph A Powell
Liked 225 Times in 136 Posts
Coppercoat best all time!
