#11 | |
#12 |
Liked 2,361 Times in 558 Posts
I ran treated and coated stock rockers that we machined to work with a 7/16 stud on my LT1's. I saw no performance gain going to a roller rocker. Limited travel lifters was a different story.....
#13 |
Liked 10,921 Times in 2,257 Posts
The truck engine liked the 7/16 studs they had less deflection than the 3/8.
#14 |
Liked 184 Times in 113 Posts
Building the Pure Stock engine replaced the 3/8 with a 7/16th stud figuring it was a good bit stronger. Cannot remember the racers name he sent me his modified LT1 SA Stock Rockers. Bought new 7/16th ball, installed them and runs smooth.
Like Billy said, he saw no gain going to Rollers. Many of our Impala Club members stayed with the Stock LT1 SA rockers installing the popular HotCam with no problems. Figuring the 3/8th Stud was not much of an issue to begin with. Wondering if someone makes a 1.5 SA Roller Tip? Use the 7/16th ball and trim the sides up to fit. Would stop all side loading on the valve and guide. I have set of original GM SA 1.6 Roller Rockers. Then again they use 3/8 stud. Saving them for a project. |
#15 |
Liked 60 Times in 12 Posts
I’ve deleted the pics of some of the pushrod/rocker arm combo’s I had”generated”, before I switched. It wasn’t any faster on track, but I didn’t have one cost me a semi at a Division race again either.
2894 STK |
#16 |
Liked 279 Times in 68 Posts
Why don’t you try them and see for yourself.
Greg Hill 4171 STK |
#17 |
Many years ago, due to the pushrod tip going through the stamped rocker arm pushrod seat, I took a set of Oldsmobile rocker arms, laser welded a piece of 4130 Chrome Moly steel that had been cut and shaped to the contour of the rocker arm pushrod seat, and then had them solution heat treated. It was a matter of longevity than performance; the modified rocker arms were heavier than the OEM replacements by a lot.
The owner of the car approached Danny Gracia at a race, showed him the damaged rocker arms and what he was planning to use in lieu of the OEM replacement rocker arms. Of course, Danny immediately said they would be illegal and he could not use them. Then, some time later, Clark Holroyd comes up with the same concept and design for Chevy and Pontiac engines and were deemed legal to use by Danny. It appears to be the case of who you are and who you know. |
#18 |
Liked 2,765 Times in 978 Posts
Any cam duration, any valve spring, adjustable push rods, adjustable rockers , roller rockers and now solid lifters. The evolution of what we have today.
#19 |
Liked 2,493 Times in 700 Posts
I had noticed that a couple times about Danny = More often years ago
I "think" he actually likes me now after 30 years. I would have never got away with modifying the cast rockers. We broke plenty of them on Mopars and a few on my Big Block Chev.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 10-31-2021 at 09:23 PM. |
#20 | |
I modified the rocker arms only to address a weakness on the OEM stamped rocker arms after the allowance of higher pressure springs and lifting the duration and overlap specs on the camshafts. They were not installed. We asked permission to use them and were rejected. My issue with Danny was the fact that later on, he approved the same exact modification from Clark Holroyd for BBC and Pontiacs. No matter how it is addressed, Danny was always controversial in many of his decisions throughout the years. |
