Old 11-07-2021, 09:17 PM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Electric Fuel Pumps...
What about the BG rebuild or freshen. I've got 2 that have been sitting dry since 2010 when I parked everything.. Any parts out there for seals and rubber parts? Hate to buy new if I can use them.. working well when parked.
Adger Smith (Former SS)
Old 11-07-2021, 09:39 PM   #12
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
I would think that even if someone doesn't sell the specific pn's for your BG pumps, you get some replacement ones from McMaster or a similar online seal outfit with some time using calipers to measure what you need. I have never had BG pumps apart though, so I could be off base on what the seals and rubber parts look like though...
Andy Friar
Andy Friar is offline   Reply With Quote
Old 11-08-2021, 09:15 AM   #13
pmrphil
Liked 348 Times in 152 Posts
Adger, I believe I've seen seal kits on racejunk for cheap money, I want to say $12.95. Worth a peek.
Phil Molski
PMR Performance
S/C 1623
Old 11-08-2021, 11:47 AM   #14
Eman
Liked 133 Times in 76 Posts
Ninja Fuel Systems sells rebuild parts for BG pumps and regulators. You can find him on FB or ebay. I believe Quick Fuel has the designs from BG and their parts interchange, I know the fuel filter elements will fit BG.
Old 11-11-2021, 07:08 PM   #15
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
https://allcarbs.com/product-categor...v=920f83e594a1
Allstate Carburetor also has all the Barry Grant seal kits and hard parts for pumps and regulators. I have used the Ninja seal kits in a BG280 as well as a 2 port regulator. The BG stuff is old but still good!
b.guggenmos is offline   Reply With Quote
Old 11-11-2021, 11:11 PM   #16
Bruce Fulper
Liked 54 Times in 33 Posts
If you are running a QJet or any other non Holley OEM carb the bypass style is the way to go.
Montieth always ran his Hatari Qjet dead head. It was set up that way when I got the car so I tried and it worked flawlessly. Didn't see a reason to change. Ran at 6, 7 lbs.
Bruce Fulper is offline   Reply With Quote
Old 11-13-2021, 11:41 AM   #17
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Bruce ,I'm certainly not saying it hasn't been done that way successfully for years , most cars had a dead head system.
Technology and product advancements provided us with the options now available and having the return line is one of them ,especially with the newer high volume /pressure pumps that have flooded the market.
Old 11-13-2021, 08:42 PM   #18
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Just the regular is considered dead head as the pump is not just slammed shut but returning fuel there instead of another line from up front.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-14-2021, 09:24 PM   #19
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Any issues using a Holley return reg with a Aeromotive 1000? I just did a pump gas Wiseco 10:1 hydraulic roller engine for a 71 split bumper I rescued, plan to hot rod it on the street. I've already run a return +Holley Blue, Is Aeromotive durable for continual use, or is a Holley blue still the standard, anyone know? I'd like to put a quiet pump on this car. Just doing research. I've got aconstant duty relay on the blue, it screams.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 11-16-2021, 02:13 AM   #20
Adger Smith
The Holley blue regulator has a very small area. If you figure the area of the jets in your carb you need a similar or larger area in the regulator to get adequate flow. Otherwise the bowls start emptying as you go down track.
The lower float level could alter the A/F ratio.
The area also applies to Needle and seats.
2ea. .130 dia. N/S will out flow a single blue Holley regulator..
In the past when I ran Holley Blue regulators they were modified for increased flow.
If your a non believer take a blue Holley regulator apart and do some measuring.
The bypass regulator helps reduce air bubbles in the fuel and gives the carb a solid slug of fuel to get in the bowl. Most carbs don't care for air in the fuel & show it in performance.
How much HP are you making?.. HP requires LBS per Hr of fuel. Design a system that provides the correct LBS. Per Hour of fuel.
