#11 |
Liked 10,822 Times in 2,250 Posts
^^^^^^^^^^^^^^^That depends on power level
#12 |
Liked 228 Times in 70 Posts
Tubular nonadjustable lower control arms. Frame reinforcement kit from S&W and a good anti roll bar is all you should need. Stock springs work fine if it sits too high you can remove the upper rubber from the spring. All of the stockers you see have weight in the rear. Afco shocks from Fastshocks for the front are most critical. Even stock gas back shocks work fine as long as they are in good shape.
#13 | |
Liked 4 Times in 1 Post
#14 | |
#15 |
Yes subframe connector kit. And remove factory sway bars
#16 |
#17 | |
#18 |
Polyurethane bushings are fine
#19 |
