#12 |
Liked 647 Times in 140 Posts
Well it’s 6:30 and the test & tune just starting. Air about 950’. Not many cars running.
#13 |
Liked 2,750 Times in 971 Posts
The RA should be much better Friday and hopefully we'll see some records set which oh by the way is a rarity these days. Nobody wants the certificate anymore. It used to be a badge of honor. Why do you guys protect the combination that you never exercise? Air that bitch out!
#14 | |
Liked 8,121 Times in 1,534 Posts
#15 |
Liked 679 Times in 180 Posts
We thought about sending the Equalizer out but a Copo spun, then Bucky so saved our $75 for the starting line bar. LOTS of good racing going on in there. La. vs Carolinas....... Phish
#16 |
Can someone in the tower at NPR flip the switch for Live Timing?
#17 |
Liked 24 Times in 12 Posts
The live timing will post at the end of the day. Sorry, technical communication issues but it will post when we are done.
Edit: Well it looks like the IT dept found a work around. ![]() Last edited by NHRA Trey; 11-19-2021 at 03:28 PM. |
#18 |
Trey,
Thanks for your response! Frank |
#19 |
Car count seems low and based on the incremental results the track seems to be loose. But seems to be coming around.
#20 |
Liked 776 Times in 199 Posts
Just heard that Duzac set the C/S record 10.09 @ 130. and couple other records in stock. Crazy fast for a 302.
Bret Velde 2003 ??/SA |
