Liked 43 Times in 25 Posts
Hi ,
what would be considered best oil pan gasket for a 440 mopar ? Milodon tin oil pan in a 68 Satellite . I have used cork/rubber , a couple bolts loosen and it weeps . Even with loctite or silicone on threads . I have the Felpro #1808 , rubber/fibre core and #1834 steel core . Preferences ? I am using a World iron block . Thanks . Tex |
Liked 10,681 Times in 2,222 Posts
Before damper and flex plate is in stalled and after pan is installed with any gasket, I put silicone all around the outside of the block/ pan joint.
Liked 109 Times in 38 Posts
The last one I used when I had my BB Mopar was a nylon one that had the windage tray built in. They make stroker version also. Never had a leak with it.
https://www.summitracing.com/parts/m.../make/chrysler
Al Wilson NSS 7160 W201 stock |
thanks guys .
Larry its in the car so cant go to that level . Al will look into those , may not work as i use a road race pan ? Tex |
If you want to you can. Drop the drag link and trans. Remove flex plate and damper. While it’s off check a bearing or too. Clean and resemble. Not a piece of cake but doable.
wowser . no way Jose' !.
Thanks Larry but i might pass on that . I actually swapped in my transbrake transmission only 3 weeks ago . Had the pan off yesterday . I think its mostly wicking down a couple of bolts that line up with cap cross bolts . No time to check bearings needed to get home . Its my daily street/strip satellite . Tex |
Sounds like a fun ride.
thanks Larry .yes a lot of fun and almost cheaper than Stock . It runs 10.20s@ 3780lbs but a few more cubes than yours
![]() Tex |
