Old 11-29-2021, 10:13 AM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default need help diagnosing brake issue
Got a brake problem that has me stumped. I have a challenger stocker that I've built from the ground up. Everything in the brake system is new. The master cylinder and 4 wheel discs are from strange(I've replaced the MC once, no change). It has a hurst line loc, brake pressure switch, and a pressure gauge plumbed into the dash. No proportioning valve.
The problem is it seems to have air in the system. If the brakes sit for an hr or so, the pedal goes just about to the floor. Pump them up, feels great, an hr later, junk. I have pressure bleed them many times using quarts of fluid.
Here's the crazy part. To diagnose, I removed the brake lines from the MC and put in a loop. Pedal feels great. Removed the loop and plugged one port and re-connected one line. Pedal feels great. Put the plug in the other port and connected the other brake line, pedal feels great. Attached both lines, pedal is almost to the floor......
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 11-29-2021, 10:22 AM   #2
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: need help diagnosing brake issue
Are you using a 2psi check valve in the brake line? What size bore MS?
SDT1DYI is offline   Reply With Quote
Old 11-29-2021, 10:30 AM   #3
pmrphil
Liked 348 Times in 152 Posts
I've had issues in the past with the calipers not being "square" to the rotor - had to grind the spacers for the caliper brackets to get the caliper to be exactly parallel with the rotor when at rest, otherwise the caliper was pressure loaded at an angle and would push the pistons back in after a while.
Phil Molski
PMR Performance
S/C 1623
Old 11-29-2021, 10:40 AM   #4
Dave1695
Liked 15 Times in 11 Posts
First question, did you bench bleed the master before installing? If yes, did you push the piston ALL the way multiple times. If not, you have air in very nose of MC. Second question, is your line lock mounted below your MC ? If it's above MC air is trapped there and won't bleed out easily. Last, forget residual pressure valves if the MC is above the calipers, gravity works!
Dave1695 is offline   Reply With Quote
Old 11-29-2021, 10:47 AM   #5
GallopinGhost
No check valves. 1.125 MC.
Yes on bench bleed. Everything is lower than MC
Brian Carpenter
Stock 1358
Old 11-29-2021, 12:07 PM   #6
340Cuda
Liked 805 Times in 341 Posts
How have you bleed the brakes?
I have had best luck using a system that pressurizes the master cylinder and then liberally bleed fluid from each caliber.
I do use residual valves.
I have had problems in the past not too dissimilar to yours that I think are caused by the larger fluid volume of the rear brakes compared to the front.
Good luck and please share you fix when you find it.
Old 11-29-2021, 12:26 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
First thing I would do is to make sure the calipers are perfectly square to the rotor. That is paramount to the brakes working correctly and not dragging. Then make sure the calipers are positioned correctly that the bleed screw is at the highest point of the caliper. After that I would take the pressure gauge and pressure switch out of the system and re bleed and check. Those two items would be suspect to not bleeding completely. You should not need a residual pressure valve.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-29-2021, 01:04 PM   #8
Al Wilson
Liked 109 Times in 38 Posts
I had a similar problem on Strange rear disc brake conversion I did once. These were two piston calipers with a bleed valve on the top and bottom of the calipers. What I had to do was take the caliper off (with brake line still attached), turn it upside down and bleed the other end that was on the bottom. Problem solved.
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 11-29-2021, 03:28 PM   #9
GallopinGhost
On the caliper alignment, I have centered the caliper bracket to the rotor using shims, so they should be centered and parallel pretty good.
The pressure gauge that's on the front of the dash is mounted in a tee. the gauge is on the bottom and I have a bleeder screw at the top.
The calipers have bleeder screws top and bottom. I did try flipping them over and bleeding them, never saw a difference.
The issue has been going on since day 1, which was before the pressure switch and pressure gauge. I have flipped the lines between the front and back ports on the MC to get better holding power on the starting lines, didn't see much difference. Once pumped up, I can get 1000 psi on the gauge.
Brian Carpenter
Stock 1358
Old 11-29-2021, 03:31 PM   #10
GallopinGhost
I use a pressure bleeder which really is a nice piece.
Right now the rear brakes are connected to the rear port on the MC....
Brian Carpenter
Stock 1358
