#21 | |
Liked 7,779 Times in 1,742 Posts
As far as "throttle stops", as long as they are mechanical and unable to be manipulated as the car is going down the track, I'm OK with them.
#22 | |
Liked 1,104 Times in 302 Posts
#23 | |
Liked 647 Times in 140 Posts
#24 |
THAT isn't what I said!
#25 |
#26 | |
The EFI guys are making steel and aluminum plates and putting them between the throttle body and the manifold.
#27 |
Liked 431 Times in 224 Posts
Why would you need 2 gaskets other than to put one on each side of the restrictor plate?
S/ST 51 S/C 53 |
#28 |
Some carbureted combos like a larger "plenum" under the carb. Some don't.
#29 | |
Yes, there are illegal accessories available for it, but you can hook up illegal boxes to just about any ignition system if that’s what you want to do. I understand that there could be a legitimate argument that any aftermarket ignition system does not belong on a Stock Eliminator car, but that’s a different argument.
S/ST 51 S/C 53 |
#30 | |
Liked 271 Times in 107 Posts
I knew a racer years ago that had one of these on a stocker,but I think he was using it for a staging device. Flip a switch and it holds the throttle open for you. |
