Old 12-26-2021, 05:56 PM   #11
Liked 10,715 Times in 2,231 Posts
Default Re: Off season maintenance/upgrades
Dont forget Belts and Helmet, I ordered those today for the pink car. I will check Dumbo to see what he needs.
Old 12-26-2021, 09:21 PM   #12
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Many good suggestions! One very important part of every race car are the shocks, front and rear. if you have not had them serviced by the manufacturer, I would recommend sending them to Randy at Fastshocks. The shocks play a very critical part of how your car works and the ability to adjust to the varying track conditions we see through out the season.
Old 12-29-2021, 11:58 PM   #13
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
One thing I find most racers overlook is changing brake fluid .
Unlike our street cars that usually see use every day, our race cars are subject to long periods of setting unused ,and many times stored in the trailer or a cold garage .
During storage the fluid can absorb moisture which will contaminate the fluid and cause corrosion and rust to form in the system.
I used to service and inspect several SCCA raced Corvettes . SCCA required the fluid to be changed before EVERY event , and believe me the fluid looked like crap every time .
Most times you can suck out the fluid from the master cylinder ,refill it and just crack open the bleeder screws one at a time and bleed out most of the fluid by gravity , and then do a finish bleed.
Use a high quality DOT4 fluid like Wilwood EXP 600 PLUS or Motul 600 or 660.
Old 12-30-2021, 12:50 PM   #14
Dave Gantz
Liked 251 Times in 125 Posts
Hi Tom, just curious, how did the SCCA verify that it was changed?
Old 12-30-2021, 03:19 PM   #15
Tom Goldman
Dave there is a inspection report that the inspecting mechanic had to fill out and verify that the fluid was changed.
I was told by the owners that the tech inspectors sometimes removed the reservoir cap and used a test strip to indicate the condition of the fluid.
We used similar test strips at the dealership I worked for to test the corrosiveness of brake fluid .
When Antilock brakes became common the manufacturers recommended changing the fluid every two years or 30K miles because old ,contaminated fluid would damage the antilock pump and control valves,
Old 12-30-2021, 07:29 PM   #16
SDT1DYI
Liked 455 Times in 147 Posts
Changed to a removable cross member so I can remove the oil pan now.
Steve Teeter STK/SS 620
SDT1DYI is offline   Reply With Quote
Old 12-31-2021, 08:28 PM   #17
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
New helmet. Pretty crazy stuff! Might put the 200 back in.
Lane Weber
Old 01-01-2022, 06:39 PM   #18
Frank Castros
Liked 2,727 Times in 961 Posts
Fuel System maintenance?
Old 01-02-2022, 01:14 PM   #19
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Sent my clutch assembly and bellhousing off for re-certification.
Kelly Lane
4991 Stock
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 01-02-2022, 03:42 PM   #20
Tom Meyer
Liked 354 Times in 120 Posts
After breaking the motor we are updating with a new build, changing engine management system. It could be a fun season. Tom
Tom Meyer 5240 SS Stock ???
