Old 01-12-2022, 12:35 PM   #11
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
Default Re: Pontiac 455 hp reduction
Sorry, but that makes absolutely no sense to me at all.
I can name several Pontiac engines that were increased by NHRA, then later reduced by NHRA.
So, are you trying to say that once NHRA has increased the hp, they can't later come back & reduce it ?
If a racer causes the hp increase then no it can't be reduced. If Nhra increases hp before it is introduced into their classification guide then yes it can get a reduction. Hope this is correct from what I was told by Nhra.
Old 01-12-2022, 12:59 PM   #12
SUPERFTAN
Liked 46 Times in 12 Posts
So if the combo is deleted because GM never made it how is it that the Yenco Nova withe 350 LT 1 IS in the Guide Book
SUPERFTAN is offline   Reply With Quote
Old 01-12-2022, 01:03 PM   #13
Glenn Briglio
Good question......above my pay grade
Old 01-12-2022, 01:05 PM   #14
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
That is the way the rule works now. If a certain combo gets HP then it is never eligible for a reduction. I was told that first hand when I tried to get a reduction on my combo. That Pontiac combo was not eligible by the rule as written.
Old 01-12-2022, 02:38 PM   #15
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
WOW ! 1st time I ever heard that. So, EXACTLY when did this rule take effect ?
Cause I'm positive that I know of factors that were increased, then reduced a couple of years later, & this was in very recent history.
That's all I'm gonna say about that.
And, who's to say NHRA couldn't just change that new rule ? How many rules have they changed ????????
Old 01-12-2022, 02:59 PM   #16
Mike Pearson
If I remember correctly it was about 3 years ago the change was made. Lonnie Grim did say they could use discretion on the HP ratings.
Mike Pearson 2485 SS
Old 01-12-2022, 03:27 PM   #17
Jeff Stout
Liked 704 Times in 281 Posts
My Olds 307 in Cutlass did not get reduction because of being hit. In my wagon I received 3 hp off. G body to B body platforms.
Old 01-12-2022, 05:04 PM   #18
GUMP
Liked 2,350 Times in 553 Posts
Are you saying that Chevrolet didn't produce a COPO Nova with the LT1 350 in 1970? I'm pretty sure that one is well documented.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 01-12-2022, 05:07 PM   #19
DG
DG's Avatar
Liked 449 Times in 98 Posts
NHRA used to provide the run data base with averages for each combo. It made it easy to understand their decisions. I wish they would post the date base and averages again.
DG is offline   Reply With Quote
Old 01-12-2022, 05:32 PM   #20
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Back in the early 80's we ran a 73 GTO in Stock with an NHRA factored Hp at 350 non ram air and 355 with ram air . There was some confusion on the factory HP rating which originally came out at 310 , but was later reduced to 290 . Pretty hard combo to run because the parts are so rare .
