#31 | |
Liked 684 Times in 289 Posts
#32 |
Liked 10,921 Times in 2,257 Posts
On the front end, work to have zero to very little toe change through the range of travel. For us that took awhile. Good luck!
Get the car the best it can be first, then when a change is made it will respond positive or negative. The days of a 20 Hp improvement with a cam and spring change are gone for most of us. I fight all the time to make the second number right of the decimal point smaller on the et slip. Hope this helps. |
#33 |
Liked 3,231 Times in 982 Posts
Budget permitting, ceramic bearings. Ever notice someone pushing a car almost effortlessly in the staging lanes? Yep, you guessed it.
#34 | |
https://www.drpperformance.net/hub-components |
#35 | |
Liked 109 Times in 38 Posts
https://negearpolishing.com/services...ring-seal-kits
Al Wilson NSS 7160 W201 stock |
#36 |
There’s a lot of good parts in bar stock and they’re easy to find. All that has to be done is cut away everything that doesn’t look like what you want.
#37 |
If you need access to a lathe try an adult education at a higher learning center. It will be fun and save you a few bucks in making that special piece. Explain to the instructor what and why you want to do this special project. You’ll learn a lot but don’t hurt yourself. The machine doesn’t now the difference between steel , aluminum, or fingers, it will cut all three.
#38 | |
Also another good one, "Rpm's are your friend."- Mr Garley Daniels Spoken like a true engine builder!
#39 |
Mr Daniels would know.
#40 |
Liked 974 Times in 310 Posts
2.25 qts man you must hate your engine..........lol
