Old 03-04-2022, 01:31 PM   #1
garyc
Liked 51 Times in 30 Posts
Default 4 corner weight b-body
building L/SA mopar b-body. needs to be at 4185 lbs , now 3396 have to add fuel system, valve train, interior , fluids odds and ends, ballast etc.
running old school s/s springs for now, 727 auto, what would be the best 4 corner weight, or percent frt/rr
thanks
garyc is offline   Reply With Quote
Old 03-04-2022, 06:14 PM   #2
Chris Hill
Liked 244 Times in 26 Posts
Default Re: 4 corner weight b-body
What combo are we talking about here?
4,200 pounds?
Chris Hill
Old 03-04-2022, 06:57 PM   #3
SSDiv6
Have never scaled that heavy of a car, however, I shoot 52% to 54% in the front. There are other variables to consider such as the wheelbase and type of suspension.
Old 03-04-2022, 08:10 PM   #4
Paul Wong
Liked 419 Times in 85 Posts
At that weight I don't see how it could not be over 50% on the rear. Making the suspension work is every bit as critical as weight distribution.
Paul Wong is offline   Reply With Quote
Old 03-04-2022, 10:39 PM   #5
garyc
1975 chrysler cordoba 400 t/quad, 4185 lbs .463 cam 4208 lbs .483 cam
Old 03-06-2022, 12:22 AM   #6
GTX JOHN
310 HP?
OUCH!
It is 294HP Iron 296HP Alum. In 72/73 Mopar with
Higher Compression
Let See: 310HP x 13.5 (L) = 4,185+ 170 (Driver weigh is added) is a total of a Svelte 4355 for L/SA
if my math is right.
Very Tough Way to Go!!
I race one of the fastest 400's in NHRA and this Combo would NOT be a dime rocket at that number
to get even 2 or 3 tenths under the index.
If you have the car and really want to build a stocker on a budget = 360 @ 276 would be much better
easier way to go on a budget - We ran the 360 for years
276HP x 14 = 3860 + 170 =4030 @ M/SA
This would be doable on a budget and I would be happy to help
Better plan on a Dana 60
3400 LBs is way lighter than we could ever get a Cordoba with a big block or even our
Satellite and we TRIED!
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 03-06-2022, 02:00 PM   #7
Paul Wong
John is spot on here. By far the The best combination here. The transmission will cost a quarter to build. Everything about this combination can be done fairly reasonable
Old 03-07-2022, 10:27 AM   #8
garyc
Smile Re: 4 corner weight b-body
To late
yes john, have talked to you in the past
Old 03-07-2022, 10:45 AM   #9
garyc
no valve train, interior, converter, fuel system, drive shaft or fluids yet, car was heading to scrape yard, got it for zip 400/727. I had spare 727 with light weight parts/TA valve body
Old 03-08-2022, 04:18 PM   #10
garyc
SO now we know the combo, anybody have any percent/weight suggestions?
