#21 | |
Alan Roehrich 212A G/S |
#22 |
Liked 880 Times in 311 Posts
Jesse,
If the 396/375 combo fits your car you might want to consider it. I believe most of the part numbers interchange. Last time I looked, the 396 will carry less weight per actual cu in & will make more Hp per cu in than the 427.( At a higher RPM) More than likely that is the combination Kevin had in his car @ the Sports Nationals. When he lived, or used east Texas as his base of operation, I did quite a bit of work for him. At that time he only had a 396/375 and a 427/430. Since he went to work for Pat I'm not sure if he has built any other engines. Give me a call at my shop 903 794 7223 or my cell 903 824 4924, If I'm busy I usually don't leave the work I'm doing to answer the shop phone, but I keep the cell with me at all times. I will hook you up with Kevin's numbers. I'm sure he wouldn't mind talking to you. I also have some parts you might be interested in. I had a customer that was going to build a jet boat engine with a virgin set of BB heads. The fuel prices & I talked him out of it. ( I couldn't ruin them ) I will try to get the casting #'s & post them & his number on this thread. I believe Kevin has a legal set of CP 396 pistons, that we couldn't use because of wrong bore size, For Sale at a very attractive price. I think I still have a good 4 bolt 396 or 402 block, I'll look today. Another way to do a 396 is a 454 with 8 sleeves. That will allow some creative machine work too. Good Luck, Adger
Adger Smith (Former SS) |
#23 |
jesse,the camaro is doing good,getting ready to go back to the track in a month or so,
with an adjustable clutch set right,it's not even close to being as abusive on parts as a trans brake |
#24 |
Adger. Thanks for the response. Where in Texas are you? I've seen your racecars at races before but never stopped by to introduce myself. If I am correct, don't you have a machine shop? Do you do machine work on stock pieces? I had planned to build for A/SA with the option to go to AA/SA. I realize I can move up to A/SA with the 396 piece, but not to AA/SA. Is this correct? The head castings for what I want to build are the same as for the 396/375 piece. They are 291, 840, 858, and 391. Let me know what numbers you find. If you'd like, email me. SSHA4899@AOL.COM Jesse
#25 |
Rick. That is true, but I won't be running a brake anymore by going to stock eliminator. Let me know how quick and fast you've gone with it. I think you've already surpassed what my smallblock ever did. Course yours is soooo big and mine was soooo small, with a rather large cam and lots of rpm. LOL. My belief, as to running the stick, is that those racers that stay with it are really good ones. Actually, I am more interested in these cars (stock eliminator) and their combinations rather than just driving. It's all about what you do with what you're allowed that interests me. Additionally, to be able to drive that stick down the track is more than I could handle. Yes, I am intimidated, I do admit. LOL. Another good candidate is John Duzac. D/S Good driver and one bad to the bone 302 (real tiny engine). Jesse
#26 |
Banned
#27 |
jesse,the best i got out of it is a 1.43 60' 10.05 at 135.1
the reason for the poor 60' is the 4.30 gear out back was too conservative,i have some 4.86's that are going in,the 4.86's on the highway will be 3000 rpm's at 60 mph,which is ok,definately my limit though. |
