Liked 66 Times in 31 Posts
So after making 3 passes back to back I loaded the car and then I noticed drops of trans fluid where the car was parked. I finally got around to jacking it up and it appears it blew it out of the vent. Is this a common problem with a turbo 350? do I need to put a catch can on the vent?
#2 | |
Liked 1,583 Times in 582 Posts
Liked 51 Times in 30 Posts
you might need a larger cooler, back to back runs will sometimes overheat tranny and push fluid out vent, i used a moroso coolent overflow tank and plumb to vent, chrysler 727
SSDiv6 that conversation went all over the place but I think I get it.
Liked 684 Times in 289 Posts
1320Racer was a colorful palette of knowledge and conversation.
Liked 216 Times in 77 Posts
Liked 133 Times in 76 Posts
Where is the fluid level on the stick after making a pass? Do you have a temperature gauge on the trans? My T350 would puke some out if the fluid level was a little high when the trans was hot. When I say hot my pan temp was usually around 150*. When fluid level was correct it would still have a mist so I put a catch can on the vent with a clear hose. Never had much in the hose but the mist even when on the transbrake and double entered with pan at 200*.
Liked 125 Times in 59 Posts
#10 | |
Liked 348 Times in 152 Posts
Phil Molski PMR Performance S/C 1623 |
