Old 04-19-2022, 08:39 PM   #1
rod
Liked 20 Times in 15 Posts
Default starter wrap?
I bought a starter heat wrap at a swap meet for a buck. was going to put it on my mini starter, but am now wondering...if it might hold more heat in than absorb? have one pipe which runs fairly close.
thoughts?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-20-2022, 09:04 AM   #2
garyc
Liked 51 Times in 30 Posts
Default Re: starter wrap?
I thought mini starters did not have a problem with heat, just the older full size?? you having a problem?? "don't fix it if it anit broke"
garyc is offline   Reply With Quote
Old 04-20-2022, 12:15 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
thoughts?
thanks Rod in AZ
Wrap the header not the starter.
Old 04-22-2022, 02:12 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
If you have one of those heat reader guns you can fire the car and read the temp off the starter. Then you would know what you are dealing with.
Dale Shearon
68 Mustang 6394
Old 04-25-2022, 09:54 PM   #5
rod
thanks for the reply's. Rod in AZ
