Old 04-05-2022, 09:06 AM   #1
Charley Downing
Liked 653 Times in 89 Posts
Default 1969 Camaro BBC Stocker AA/SA-B/SA
1969 BBC Camaro Stocker AA/SA, A/SA, B/SA
Black interior super clean and well maintained
Exterior dark green 80%,mint green strip and pink strip.
Originally Arizona car unmolested perfect trunk and floor pans. Has been a race car the last 51 years. Has title. Originally owned by Les Rider (1970-1981) then Mike fuller (1982-2017). This one of the nicest/clean 1969 Camaros out there. If you’re looking for a clean BBC 69 Camaro you will not find a cleaner one.
Car has been updated in the last 5 years by MPR.
10 point chrome moly cage in 2017 by MPR
Following updates and New parts were done in 2020 by MPR
Copo style wheelie bars
New strange 35 spline axels, spool and pro gear
KTRE rear end housing
Strange rear brakes
Strange master cylinder
Rear wight bars
Fuel gallon aluminum cell
Re-work/update front Wildwood brakes
Re-work/update front end (Tom Stiles)
Re-work/update rear suspension and springs (Tom Stiles)
Strange double adj shocks front and rear
These Updates alone were over $15,000
Auto Meter gauges and Tach
Original bucket seats
Original wood steering wheel
CSR water pump
Magna flow fuel pump
MSD ignition
Turbo action shifter
Elston step stainless headers
Kilgore 400 trans freshened by Joel 25 runs ago
ATI converter fresh 25 runs ago
Bogart D10 wheels all 4
M/T radial’s rear
Clark Holroyd Holley carb
Engine 396/375 Steel head NHRA rated at 412 hp with Automatic
Fresh zero runs. Last time car/eng was raced in B/SA trim (summer2019) @#3670 lbs it ran 10.55 -70 under index.
Last time car was raced before it was parked fall of 2019 it went 10.22 at 128.5mph in AA/SA 50 lbs from A/SA min weight with Kevin Zaskowski driving it at Norwalk nationals 2019 at 3390-3405 lbs. both B/SA and AA/SA were in none class heads up mode.
This engine has gone 10.20s @128mph in B/SA in class mode in a different car.
Engine was original built by Darrel Wikel, Currently Maintained by Keith Lynch.
Engine is currently out of the car and can be inspected
Complete car $52,000
Call Chuck Downing 517-605-8309 or Paul Wong 702-281-8520 for more info. Car is located in SE Michigan
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 04-05-2022, 09:55 PM   #2
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: 1969 Camaro BBC Stocker AA/SA-B/SA
Can the car be bought less motor , trans & converter
Thanks David
If you only want to answer by a phone call I under stand
and will call
Willyracer is offline   Reply With Quote
Old 04-19-2022, 12:48 AM   #3
heavy225
is this still avaiable, need to see pics please heavyduty225@bellsouth.net
thanx
heavy225 is offline   Reply With Quote
Old 05-11-2022, 07:43 PM   #4
Paul Wong
Liked 419 Times in 85 Posts
Car also available now with a fresh Aluminum Head 375/396 rated 405hp turn key for $55,000
Paul Wong is offline   Reply With Quote
Old 05-11-2022, 08:07 PM   #5
Paul Wong
Sold
