#11 | |
Liked 405 Times in 70 Posts
Go use the Columbus qualifying sheets from the past 2 seasons...or basically any divisional qualifying sheet where more of the cars that aren't as far under the index are likely to show up...and you'll find significantly more cars that aren't more than a few hundredths under the index especially in the heat of the summer. Lowering indexes any further won't do anything to make the faster cars come back to the slower ones. It would, however, make several cars completely useless thru the summer months. In stock eliminator...where the car counts are already starting to falter a little bit...is shrinking the field of available cars for divisionals or "non-Indy" nationals really what is in the best interest of the class? |
#12 |
Indy is Indy, I get it, but 171 cars in my opinion is a fair example, especially without the AHFS in effect.
#13 |
The issue is at the top of the qualifying sheet not the bottom and maybe the rare combos at the bottom need HP adjustments.
#14 | |
I truly don't believe lowering indexes is the right solution for this perceived "problem" at all... |
#15 |
Liked 535 Times in 110 Posts
The only way the AHFS can be made to truly work is by looking at the 1/8 mile, 1,000' E.T.'s and 1/4 mile MPH. When you see someone run 10.80 @ 100 MPH, for example, it's no secret that they're blatantly trying to protect their HP.
Jim Kaekel 3836 STK |
#16 |
Liked 1,942 Times in 584 Posts
Lowering the index will not help fix the inequalities in the AHFS. That will only help to kill the class even worse that it is now. There is some new blood coming in to the stock and super stock classes but no where near enough to keep the class alive long term. This should not be a rich man only class. I have a slow car and typically qualify near the bottom of the sheet for several reasons. One is my combo is not competitive due to the HP rating. Two is the cost to improve my car would be exorbitant to try to get near the top of the sheet. Three is what is the sense to spend 20-30 thousand dollars on an engine and another 10 thousand on a transmission and converter to race for a $1500 purse. I just won Super stock at the division 2 race in Reynolds Ga several weeks ago. Winners purse was $1500. So far I have gotten $300 in contingency and I expect a few more will pay so a total of approximately $2200 for the win. I spent $320 to enter and another 400 in diesel fuel in the truck. 120 in race fuel. That leaves me about $1400 clear after expenses. I dont do this for the money by the way.
I say raise the indexes 2 tenth and leave the trigger where it is and maybe that might get a few more to hit the trigger. Possibly some retired racers might come back and a few new racers might get started and grow the class back again.
Mike Pearson 2485 SS |
#17 | |
Liked 2,336 Times in 464 Posts
And I thought you had one of the fastest ones!!! Last edited by B Parker; 05-27-2022 at 10:10 PM. |
#18 | |
#19 | |
I've got and idea anyone that averages better than a .30 light at the next race they add some time to their reaction times. Maybe make that .30 a .45 And if they are .20 and better make it a .035 Would that make you feel better. |
#20 | |
