Old 04-14-2008, 09:19 PM   #1
Stephen Hughes
Default 1992 Camaro Front end "shimmy"
What can I do to keep the front end from shaking the steering wheel out of my hands after a wheelie? First time out leaving off the t-brake Saturday, when the front end would drop it would just about shake the steering wheel out of my hands. I have been told my front end alignment isn't set up properly. Any ideas on where to start?
Stephen Hughes is offline   Reply With Quote
Old 04-14-2008, 09:55 PM   #2
SSDiv6
Default Re: 1992 Camaro Front end "shimmy"
You need a steering dampener. Ed Quay sells what you need. Check out their catalog, Page 17.
http://www.edquay.com/camaro/82-92camaro_catalog.pdf
Old 04-14-2008, 11:10 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Also ,it would be wise to install Ed's tie rod kit. ......It makes a major improvement in the bump steer. .....The damper is a must have on this front end. ....Tom
Old 04-15-2008, 08:41 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
had this issue with my 80 big block camaro,front end comes up with the tires off the ground,tires are not rotating,when you car comes down it may be coming down not level,more than likely the right would hit first(pulling the wheel right)then the left would hit(pulling the wheel left),even if you install a steering damper it mite still jerk the wheel,do you run the stock rear sway bar? does the car drive good other wise gmonde
Old 04-15-2008, 09:00 PM   #5
Stephen Hughes
The car drives good otherwise, and I am running the factory rear sway bar. I've seen cars wiggle the front wheels a little when they come down, but this thing felt like it was doing the same thing funny cars do after the burnout sometimes. It never did this until it started pulling the whels a good bit. I see stockers and super stockers doing giant wheelstands, but look just fine after they come down. Are they all using the Dampner?
Old 04-15-2008, 09:46 PM   #6
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Stephen,
I'm not sure where your located but, in Dayton, Ohio is a racer by the name of Richard Doane. He's one of the best on front ends in this part of the country. I don't have his number but I'm sure someone on here will. He also races a Camaro about that same year.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-15-2008, 09:50 PM   #7
SSDiv6
Stephen, this is a known issue with the 1982-1992 Camaros. Ed Quay addressed this issue for the 182-1992 cars with his front end components. The suspension applicable to 1967 thru 1981, is not the same design as your car; the early cars have an upper and lower control arm with a conventional shock absorber. However, from 1982 and on, the suspension is a strut design.
Old 04-17-2008, 04:36 PM   #8
Dave Casey
Liked 797 Times in 165 Posts
The exact same thing happened to me 20 years ago when I put my 86 camaro together. Put a damper on it is all you need to do. If you can fabricate a little just get a damper from a volks bug and adapt it to the drag link. it is easy to do.
Dave Casey 1330 STK
Old 04-17-2008, 06:06 PM   #9
Stephen Hughes
I can do some fabrication, Anybody have a pic of one installed? Should I be attaching one end to the drag link and one to the frame, or one end to the K-Member?
Old 04-17-2008, 06:30 PM   #10
Doug Blackley
Doug Blackley's Avatar
The Ed Quay kit has a bracket that welds onto the frame and another that welds onto the center link. His kit comes with pic instructions.
Doug Blackley 1697 STK
