Old 06-05-2022, 10:40 AM   #41
Doug Hoven
Liked 867 Times in 165 Posts
Default Re: Ahfs
Originally Posted by B Parker View Post
How would you guys in the lower classes feel if they lowered the index's by .1 in cars from K up. Just a thought BP
I think that wouldn’t be a bad idea. As long as the majority of racers in the effected classes were okay with it.
1189 F/SA
Defunzalo Racing Enterprises
Old 06-05-2022, 10:47 AM   #42
GUMP
Liked 2,354 Times in 554 Posts
Default Re: Ahfs
How is that a good thing? There are lot of fast lower class cars.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-05-2022, 10:59 AM   #43
B Parker
Liked 2,336 Times in 464 Posts
Default Re: Ahfs
Doug, I'm just trying to figure out a way that the 1970 402/375 Nova now 415 hp doesn't happen to other combo's. Heads up runs in the upper classes in great air can really screw up a combo. Not just in the A and B cars. One run just over the 1.20 mark and now and the Nova's had to add over 100lbs. A lot of weight for one run. I'm waiting for the 350/255 1969 Camaro's to get the hit. Several have danced around it. And that's not with running heads up. There are a lot of them maybe at that time people will get my point. BP
Old 06-05-2022, 10:59 AM   #44
Lyn Smith
Liked 984 Times in 198 Posts
Default Re: Ahfs
Not a good idea to lower the indexes. Take for example Div. 3 first race Indy in May. Qualifying list shows about 5 cars, me included, at the bottom of the list just barely under the index. Lower the indexes and none of us are under the index. We do not need to chase anymore racers away from participating. Lowering the indexes does not make any sense.
Old 06-05-2022, 11:07 AM   #45
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Default Re: Ahfs
Personally as a fan and no longer a racer I like to see performance and loath when racers de-tune their cars to protect their combinations for what? What are you saving it for? Why are racers making deals to race to 1000 feet during class eliminations?
For old school guys like me it makes me question why you guys do this crap.
Let it fly!
Frank, lets say you are running your Mopar in B/SA, and you are 3 or 4 tenths behind, so you spend 4 or 5k on a set of cylinder heads, 6k on a pro trans, maybe 3k on a set up modern pistons and rings. So now your 13 or 14k investment puts you in a spot where you are competitive with most of the other B cars. Would you now qualify .90 under at most races, hit the 1 second under trigger a couple times, just to be rewarded with a hp adjustment at the end of the year? Once that happens a couple times, you run out of modern rule updates to spend your money on. Or do you run the car heavy with timing knocked out until you have a heads up, or want to qualify higher in the ladder, or make the field at Indy? Some of these combos dont have the luxury of a replacement carb, heads, block, cranks with smaller journal rods etc.
Make the quotas at races larger so you have to qualify to get in, award points for records at races that count towards afhs, and or give points to top qualifiers and you may see the fast cars show what they have at times.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 06-05-2022, 11:10 AM   #46
B Parker
Default Re: Ahfs
Originally Posted by rboyle View Post
How the he'll does lowering everyone's index a tenth fix anything?
So if you are a fast car that can run -1.30 and you lose a tenth then you are -1.20
Yet a typical -.80 good car is now a -.70 good car and the bump at Indy goes from -.85 to -.75 and number one is -1.20 or so. Maybe it eliminates mineshaft conditions being early and late in the season but it doesn't fix a fast combo being fast it only hurts the slower guys
Rich I totally disagree with you all except about the slower cars. Your car is a good combo. In good air it should be able to run 1.20 under or more. If a typical car runs -.85 under and now they run .75 under it doesn't make any difference to them everybody in their class also got the same index change. But for the faster car it gives them some breathing room for the instant 1.20 hit. Several cars at the Atco open went 1.20 and faster. There were several more that could have also including mine. What if that was a Divisional and there were a few heads up with those cars. I would hate to see cars that on kill in good air that are just at that 1.20 point end up getting HP when others in their class are already faster than them. BP
Old 06-05-2022, 11:26 AM   #47
Billy Nees
Liked 7,780 Times in 1,743 Posts
Default Re: Ahfs
Wrong! There are a FEW fast lower class cars.
WAY out of proportion to the number of fast higher class cars.
Billy Nees 1188 STK, SS
Old 06-05-2022, 12:03 PM   #48
Default Re: Ahfs
Actually, there are quite a few fast lower class combinations that are never going to get built.
1, They are perceived to be at a disadvantage in the eliminator
2, They can't be bubble - packed together.
Might as well deal with reality here.
Carry on.
Old 06-05-2022, 12:21 PM   #49
GUMP
Exclamation Re: Ahfs
Do you read Nitro Joe's Stats?
A quick scan of the 2021 Stock Eliminator data tells a different story. Statistically, the performance of the lower classes are very similar to those in the mid and upper classes. The upper classes are just WAY MORE populated.
There are a couple of exceptions in the front wheel drive classes. You know better than I wether that is because those cars are over factored, the indexes are wrong, or the cars are "Dime Rockets".
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-05-2022, 01:36 PM   #50
Billy Nees
Default Re: Ahfs
I think that you would know that I'm never very far from my Nitro Joe's.
You're making my point for me, statistically the classes may be similar IF you're only going by the fastest combos in each class BUT "the upper classes are just way more populated" and there are dis-proportionally more fast combos in the higher classes.
Just as a science experiment, pick a number. What's "fast"? 8 under? 9 under? I'll spend some time in Nitro Joe's and look into what percentage of combos are fast in what classes and I'm willing to wager that the higher classes are going to come out on top!
