Old 07-05-2022, 02:33 PM   #1
BobbyH
Liked 62 Times in 19 Posts
Default Fuel tank choice and size for a stocker
Am upgrading my fuel system from a stock tank in my Chevelle.Any advice appreciated.
BobbyH is offline   Reply With Quote
Old 07-05-2022, 03:27 PM   #2
Liked 11,012 Times in 2,263 Posts
Default Re: Fuel tank choice and size for a stocker
Just because it is a AN10 fitting on the tank outlet. Make sure the hole in the fitting is the correct ID size for what ever size the AN fitting is advertised. I had to resize mine.
If you can put your car on a set of scales and move 25 to 30 lbs around to help the balance of the car with the simulated weight of fuel and fuel cell.
I use a five gallon metal tank with foam in it.
Old 07-06-2022, 08:37 AM   #3
Kirk Morgan
Liked 81 Times in 45 Posts
Also put weight in the drivers seat equal to your weight.
Kirk Morgan is offline   Reply With Quote
Old 07-06-2022, 09:02 AM   #4
J&S Racing
Liked 327 Times in 87 Posts
I really like the simplicity of the Aeromotive stealth set up.
Old 07-06-2022, 09:36 AM   #5
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
I like the 2.5 gallon ones on Ebay, they have 2 -10 fittings, a return, and a rollover valve. you can get them with and without foam. I know the foam can come apart from certain fuel, I just feel with a -10 return on my car, the foam will de aerate the fuel.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 07-06-2022, 09:46 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
If your car is close on weight use a small cell. I have a 3 gallon cell in my car and usually run 2 gallons in it. I can get real close to minimum weight with a gallon. I have a Jaz plastic cell. No foam. No sense carrying more fuel than needed.
Mike Pearson 2485 SS
Old 07-06-2022, 07:42 PM   #7
Tom O
Liked 151 Times in 36 Posts
I put a Rhodes 4 gal alum. no foam cell in my 68 Chevelle earlier this year. about $175 at Summit.
Tom O is offline   Reply With Quote
Old 07-07-2022, 05:48 AM   #8
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Fuel tank choice and size for a stocker
Good morning to al,
I put a 5 gallon cell in my car 1969 Chevy Nova body just at the time NHRA allowed fuel cells in Stockers. Good thing at the time my second stock gas tank rusted out. Also, good idea to leave the foam out, the foam came apart in my cell. Just recently a circle racer that I do work for had a flooding problem with his Q-Jet equipped Bomber car, guess what was in his fuel bowl, besides fuel ............
The smaller cells don't splash the fuel around like an OEM size tank does, besides being safer, and I can make 3 runs safely without filling up after each run. Just my Two Cents from my little corner in the world.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 07-18-2022, 06:33 PM   #9
BobbyH
Thanks for all the tips....Blessings BH
Old 07-19-2022, 12:05 PM   #10
B Parker
Liked 2,358 Times in 467 Posts
Take the foam out!!! Bp
