I'm thinking of trying to make one of my transaxles into a clutchless deal.
I know it's blatantly against the rules but I see guys on Facebook swinging away and never moving their left leg after launch. I guess it's a look the other way deal like heads and manifolds. Bobby F sounded shocked when Jim Hughes said he uses the clutch to shift LOL I know you couldn't do it with the old DNE T 10 style square lugs.You could probably pull it out of one gear but would surely burr up the next one. I'm not familiar with Jericos. Could someone post a pic of a gear shifting face and the slider? Might as well join em' ;-)
Liked 662 Times in 187 Posts
The clutchless trans will bounce out of gear when you rock the car in gear. A clutch trans will not come out of gear. I would look into face plating your trans if its possible. Tech will check this and I have been checked before. Just a heads up for you while you are building your clutch trans
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
Liked 239 Times in 114 Posts
We got a tour of Liberties facility and he builds most of the transmissions for Pro Stock . Those transmissions are truly "clutchless" , once the car leaves the starting line there is never a point on the run that torque is not going through the drive shaft . This is a lot different that a "slick shifted" transmission , that drops torque to zero each time the gear shift is pulled . The engineering involved with making a true clutchless transmission is quite impressive !
#4 | |
Checked at Indy..Doug Nash 4+ 1 (minus 1)..No problem. Anyone been checked by a ghost tech man lately?
Liked 275 Times in 76 Posts
Mark
The clutch assisted sliders and faceplates have different tapered angles so they lock together in my GF5R. The clutchless have a straight angle on the faceplate and the sliders have a ramp with a straight angle, so they do not lock. Just because someone is not using the clutch to shift means nothing. How they have the clutch setup and a trans that is face plated and enough leverage to pull the shifter out of gear, and into the next gear. Or hitting the rev limiter, will unload the trans and allow easy shifting. A clutchless will not stay in gear unless kept under a slight load. A clutch assist will stay in gear without a load. My trans was clutch assist when my car was a stocker, I never used the clutch to shift going down the track. When I switched to SS I ran the same exact clutch assist trans, until I changed gearing and had it converted to clutchless for $250. The only changes were the clutchless sliders and faceplates. The picture is my trans apart for service last winter. 5th gear is not clutchless all other gears are clutchless and show the ramp. 1st, 3rd and 4th gear sliders are chewed up from the clutch being set too tight, and driver error over several seasons.
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 07-21-2022 at 07:13 PM. |
Liked 15 Times in 9 Posts
This season I put a re-geared clutch assisted
Pierce Jones 1995 Camaro D/S #3102 |
Yes, I understand the clutchless set-up.
Now, those faceplates only have 7 notches. Assume the slider then has a matching number of engagement dogs? What holds the plates on? Those pictured don't look like they've been welded. Picture of slider, anyone? See, I told you I don't know anything about this modern stuff. ;-)
Liked 2,746 Times in 969 Posts
Herb McCandless is no longer a contestant.
But...................He should be!
Nobody wants to talk about this subject?
Understandable ,but c'mon..everybody's doin' it.. ;-)
