Old 08-01-2022, 08:52 AM   #1
garyc
Liked 51 Times in 30 Posts
Default dully brakes
not sure where to post ?
1998 V-10 dully, changed front pads 2-3 times 160,000 miles normal with 10,000lbs towing, had to do rear axle seal this weekend. rear drums 13" shoes look fairly new have never changed since new, , are they not working?? what do I check?? I know fronts wear faster then rears
gary
garyc is offline   Reply With Quote
Old 08-01-2022, 09:53 AM   #2
Barry Polley
Guest
Posts: n/a
Default Re: dully brakes
Most OEM dually brakes will last forever. Make sure to go back with OEM. I have 205k and original rears. Feeling guilty so I’m changing them.
Old 08-01-2022, 11:05 AM   #3
Eman
Liked 133 Times in 76 Posts
Brake fluid attracts moisture. 24 yo wheel cylinders belong in the trash would be a good starting point.
Old 08-01-2022, 01:51 PM   #4
garyc
OMG I didn't think my truck was 24 years old wow
Old 08-01-2022, 02:48 PM   #5
Ronnie Hamlin
Liked 29 Times in 8 Posts
Is this a FFFFord V10 dually or a Dodge V10 dually? I don't know squat about a FFFFord but on the late 90s Dodge duallys with rear drum brakes we used to swap the rear wheel cylinders to chevrolet or gmc duallie wheel cylinders because they had a larger diameter piston than the Dodge wheel cylinders. Braking was vastly improved and it was a bolt in swap.
Ronnie Hamlin is offline   Reply With Quote
Old 08-01-2022, 03:26 PM   #6
garyc
DODGE dana 80, same year GM?? yep look the same, gm 1.18 dodge 1.06 bore
Old 08-03-2022, 11:00 PM   #7
bry-war
Liked 2 Times in 2 Posts
Didn't most of those have a brake proportioning valve over the rear suspension that compensated for the amount of weight over the axle (due to squat)? Suppose that has failed?
bry-war is offline   Reply With Quote
Old 08-04-2022, 07:18 AM   #8
Ralph A Powell
Liked 225 Times in 136 Posts
We had problems with that on GM dualies in past!
