Old 07-23-2022, 08:32 PM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Class run off
How cold are folks chilling their cars for heads up races?
What brand off chiller do you recommend?
littlemanjoe is offline   Reply With Quote
Old 07-24-2022, 05:23 PM   #2
Default Re: Class run off
When you see frost on the cylinder heads, you're getting close...
Old 07-24-2022, 06:12 PM   #3
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Chilly Willy iceless is the Cadillac of chillers, most racer use there own home made version where you run a coil in a cooler filled with ice and a sump pump 110v powered.
All that aside though timing is everything. You can chill t down to 45 degrees in your pit and push it up and then an oil down or track prep delay and maybe a shutdown after burnout because the pair in front of you had an issue and all that hard work goes to waste. So it is best to time it properly and wisely.
Old 07-25-2022, 12:56 AM   #4
GTX JOHN
As COLD as we can possibly get it!!
Pretty much the same as my Beer.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 07-25-2022, 07:43 AM   #5
Liked 10,836 Times in 2,252 Posts
If you don’t have coolant in the intake like a six pack you can get it too cold and it will die on the staring line. Nothing is more embarrassing than having to restart your car when the tree is green.
Old 07-25-2022, 08:44 AM   #6
Billy Nees
and yours isn't the only combo that can be too cold!
It's just another one of those things that can't be taken for granted, it has to be tested.
Billy Nees 1188 STK, SS
Old 07-25-2022, 08:49 AM   #7
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Class run off
Good morning Larry and to all,
If you can get it that cold, then maybe you need to hook the choke back up!
With my Iron Intake, I can't get it cold enough, that's me, maybe my tune up is too fat.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 08-02-2022, 06:28 AM   #8
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Contact Paul Pittman, nice chiller! https://twistandshoutracing.com/index.html you can check the chiller out on the link provided. I love mine and it gets engine super cold in 20 mins,
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 08-03-2022, 02:39 PM   #9
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Does anyone have a parts list for the radiator hose fittings? Thanks
427FE is offline   Reply With Quote
Old 08-04-2022, 10:59 AM   #10
Jiffy Tight I think
