Old 08-11-2022, 07:42 PM   #11
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default Re: Chevy starter issues
Some of those GM trucks and vans had a flat braided ground wire from the pass side engine block to the frame. They like to rot off and cause problems like yours.
Old 08-11-2022, 09:40 PM   #12
jimmyparker
Liked 309 Times in 88 Posts
I had a similiar problem with a non GM vehicle, it would start fine then let you down when it was least expected. The cure was found when while attempting to start smoke was observed coming out of one of the battery cables, it was replaced and problem went away.
jimmyparker is offline   Reply With Quote
Old 08-12-2022, 10:35 AM   #13
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Most of the suggestions are good, check your battery cables with an ohm meter for high resistance. after as many miles as you are stating the cables may have incurred corrosion. The cables would be affected by under hood temperature.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-12-2022, 05:46 PM   #14
ken robinson
Liked 224 Times in 87 Posts
My old 1998 C2500 had doubled or stacked positive battery cables that I had to pull apart from year to year and clean and grease 1 cable was for just the start the other was for the everything else
Old 08-12-2022, 05:58 PM   #15
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Chevy starter issues
Thank you all for your contributions. All of them certainly do apply to GM Hi Torque starters. All your suggestions were good ones. Heat certainly applies to starters, relays, and all other matter of electrical things. The truck has new cables. I converted it over to the 24 S style battery about 15 or so years ago.I also fabbed up and installed an auxiliary battery tray for it and installed it on the driver's side of the engine compartment across from the OEM tray. The auxiliary battery has a long cable that connects it direct to the positive post of the battery in the factory tray. The auxiliary battery has a shorter cable directly connecting the ground post on the aux battery to the alternator bracket. That's directly bolted to the driver's side cylinder head. The ground from the main battery is bolted directly in the OEM configuration to the AC compressor stand. The main battery cable from the OEM battery goes down to the 3/8"stud on the starter. The starter activation wire came off the solenoid, runs through a tubular heat shield behind the engine on the right side away from the right exhaust manifold. I had added another wire to that post, ran it through the heat shield and up to the firewall near the distributor, pulled it through a grommet, and ran it under the dash to an auxiliary push button switch to assist with hot starts. None of the original side post battery hardware or cables has been there for some time.As I had the starter out a time or two recently to search for this hot start issue, I noticed that the wiring through the tubular heat shield looked pretty bad from an insulation standpoint.I went down yesterday and bought a 14 foot roll of 10 gauge insulated copper wire and some eyelets. I began by soldering and crimping the eyelets to the ends of the wire, fed both starter engagement wires through the heat shield with the new battery cable that I bought, finish tightened my starter and all the terminals, then located the 10 gauge purple wire from the ignition switch, cut and spliced it all very securely, then hooked it all up. I have an auxiliary push button switch under the dash, that was part of my hot start problem elimination, but the button had gotten so hot inside it had come apart internally. That's next to replace. Right now, the truck starts so well its hard to believe its the same truck. All I gotta do now is replace the auxiliary push button. Another thing I noticed, the two battery ground cables attach to the engine. It seems to me that a better path to ground could be achieved by getting a battery cable with two eyelet connections on it, like a Ford starter cable, then attaching one end of that to a good dedicated ground on the engine and the other end directly to the frame, plus at least a 10 gauge wire auxiliary ground to the body from the frame. That is to prevent any voltage drops from occurring anywhere in the system. Right now, the truck starts and works better than it has since I bought it. Seems like getting back to solid basics here cleared up a lot of things. Thanks for the tech advice!
Old 08-13-2022, 06:26 PM   #16
Greg Reimer 7376
Final note-- I checked at the lower corner of the right head, there is a flat woven ground strap that runs from the head surface directly to the frame. The other leg of this flat woven strap attaches to a dedicated body ground at the lower corner of the heater/AC box. This thing is definitely grounded! I never really cared for the side post battery when it came out about 1970 or so. The positive post seems to leak, corroding the connector and the terminal inside the battery. Often they break off all by themselves. Another thing to get rid of,I suppose.
