Old 03-09-2022, 09:46 AM   #481
Billy Nees
Liked 7,782 Times in 1,743 Posts
Default Re: Some "Dime Rockets" for the 4TH!
It should probably run pretty good. The 60* V6 has been done before (right Yac?). I don't know what transaxle you would use (125?) and I'm not sure what 4 speed transaxle came in it. It's an OBD1 car so you would probably wind up putting in an aftermarket ECU to tune it but there are some older ones popping up used.
You're off on your weight because NHRA did away with the 17.5 lb. class so you would wind up in BF at 2650 (doubtful) or the new CF at 3115.
I know that there's an older Grand Am running around D1 that's real fast but I think it's a Buick motor.
Billy Nees 1188 STK, SS
Old 03-09-2022, 12:54 PM   #482
Originally Posted by mike britt View Post
Any body ever look into building a 95 Grand Am with the V-6. 201 cubic inches and a pretty good size throttle body, .409 lift cam, fairly good compression, 15.15 index, seems like it wouldn't be too hard to get that thing under the index. Rated at 150 hp and around 2700 pounds.
It wouldn't be too hard to get one under the index.
Actually it's .430 lift in FWD...Comp has the blanks and can make you one with street and strip lobes @ .430 lift. Original duration is about 196 @ .050.
Now, if you want to go fast, it will take some serious hands on fabrication.
Earlier non-electric T 440 should bolt in.
3 speed 125 requires fabbed mounts and a custom right hand axle shaft. Same 245 mm converter, either way.
Log type manifolds are junk. Real headers will take another serious hands- on effort.
Now you'll end up with a fair amount of torque in a FWD car. The car will need a major
weight re-distribution to make it consistent.
I would seriously think about a slower class V 8 or V6 2 bbl. car, instead of this one.
(PS..it's rated at 155 hp)
Old 03-09-2022, 04:35 PM   #483
mike britt
Liked 66 Times in 31 Posts
It's sitting in my yard so I was just looking at it. Probably should've done that one instead of the IROC I did.
mike britt is online now   Reply With Quote
Old 03-09-2022, 04:38 PM   #484
mike britt
Mark, do you think those primaries are long enough?
Old 03-09-2022, 05:50 PM   #485
Yup.. The length was dictated by the need to get it out the front header well.
The rear was just a match, dimensionally.
I guess it didn't hurt it .It run 1.05 under on the first full pass ;-)
Old 03-20-2022, 10:42 PM   #486
1986 C10 , 800 Q jet , .430 cam, 190 hp! You guys can finish the equation ;-)
Old 03-21-2022, 07:22 AM   #487
Billy Nees
Definitely COULD qualify as a "Dime Rocket"!
It also goes to show that the people running this"$#1T Show" don't know cars or combos.
Old 03-21-2022, 07:50 AM   #488
Liked 10,761 Times in 2,237 Posts
After all of these years I have a “Dime Rocket “?
Old 03-21-2022, 08:44 AM   #489
Billy Nees
If you say so, I'll take your word for it!
Old 10-17-2022, 03:03 AM   #490
89bird
I recently seen a local guy racing a basically all stock 97 camaro with a lt1 auto combo, from what he tells me it has some suspension upgrades which he bought all used and he paid 1500 for the car because a blow head gasket. Not the fastest but consistent, and definitely under 5 grand the only weak point on the car is the rearend he says.
89bird is offline   Reply With Quote
