Old 10-20-2022, 07:25 PM   #1
SGSST109E
Liked 126 Times in 61 Posts
Default Onan 7kw generator problem
At the Dutch the generator was off when I returned to the trailer. Has gas and oil. Push to start and it starts then shuts right off. Any ideas???
SGSST109E is offline   Reply With Quote
Old 10-21-2022, 12:07 PM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: Onan 7kw generator problem
What code is displayed on the start switch when you attempt to re-start it?
Should be 3 3, then press stop once, and it will flash the actual code.
Old 10-22-2022, 06:52 PM   #3
SGSST109E
Got a chance to check the code. It is 45.
Old 10-23-2022, 12:36 AM   #4
voltdr
Liked 100 Times in 51 Posts
You didn’t mention how many hours are in it. Remove the brush holder. Shine a flash light into the hole. Crank the engine and see if the rotor is turning. If not, the belt or engine coupler is broken. The generator needs to make AC power to run.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 10-23-2022, 04:52 PM   #5
SGSST109E
Thanks Dan, It has just over 2,000 hrs. It looks like they built the trailer around the generator. You can't even get the cover off to be able to get to the back of the generator. I am going to have to take the internal box apart to access the generator to work on it. Then make a new cover that would be removeable from the inside. The all aluminum trailer was built in 2008.
Old 10-25-2022, 12:59 PM   #6
cad
cad's Avatar
My 2001 Onan cmm7000 efi is also putting out a 45 code... the rotor turns on mine while cranking. I checked the initial things that Rich Biebel recommended, and it ended with "best to have a pro look at it vs throwing money at it.".
Mine has 945 hours. Last time it ran was on a weekend when it was literally about 93 degrees, and I ran it all weekend with the AC on.
Keep us updated, as will I when I get a chance to get the trailer to the local repair shop. Mine is in the gooseneck....
btw... I believe Rich's phone is area code 973.... you may be able to run it up to him....
Clark
Old 10-26-2022, 07:23 AM   #7
SGSST109E
I have a lot of work to do to make things accessable so it can be worked on. There is no way to get the cover off the generator the way its mounted in the nose of the gooseneck. I opening up the enclosure from the inside so the cover of the gneerator can be taken off. I am also going to look at raising it a few inches because the shield that covers the bottom to access the belt is inaccessable the way its mounted.
Old 10-30-2022, 07:22 AM   #8
SGSST109E
Well I found out the only way to access the belt was to remove the generator from the trailer. I was able to lower the goose neck low enough to use a cherry picker to remove the generator. I have a shop crane in my garage to help me remove the engine assembly from the base. Unless you have the tools and equipment to do this job don't even try. The belt is burried behind the engine flywheel and the alternator. Its a small serpentine belt maybe 5\8" wide 4 ribs. I am freshing up all the hoses, tune up, valve adj etc. Order parts from the Onan website.
Old 11-01-2022, 08:48 PM   #9
Dyno
Dyno's Avatar
Liked 691 Times in 205 Posts
My 7.5 Onan diesel would run 3-5 minutes then shut off. If I let it sit a while, it would restart then shut off again. I thought it was a fuel filter issue. I opened the lower access door and found the water pump belt broken. I replaced the belt and it runs fine. It is a terrible job to do. Once you get to the belt, that was easy. Getting the top and side covers off and on was the hard part. My arms look like I was playing with barb wire.
Dyno is online now   Reply With Quote
Old 11-03-2022, 07:48 AM   #10
SGSST109E
My gas 7kw is air cool and you have to pull it out of the trailer to work on it. Removing the cover is extremely difficult to remove. Mine case has 4 torques screws holding it on. I am going to weld wing nuts to the top of the screws so the can be removed by hand. You can never reach the screws in the trailer cabinet with a ratchet unless you jack up the generator to get your hand in there.
