#11 |
Liked 8 Times in 7 Posts
72 GTO.
Car launches straight, carries the wheels But now has a traction issue: Initial hit and spins recovers 10 feet out with loss of .08 to .1 at 60 foot with 3500 launch on 2 step on 5000 convertor New best with a 6.41 at 105.5 and later spun at 106. That was an improvement of over 4 mph when I ran a 6.58 at 101.8 from a carb tune, slight port match and a change from 3.73's to 4.11. Still launching at 3,500 - 2-step with 5,000 still to grab. Turbo 400 4.11 Pro gears with MT 10.5w x 28 slicks Front suspension: QA1 Pro Coil Double Adjustable GM coil over conversion system with 350 # springs Adjusted to 90/10 settings Low friction control arm bushings and ball joints Total Race Weight 3440 Front weight 1860 Rear weight 1580 Percentage Basis Front to rear 55% to 45% Rear suspension: Full length Competition engineering adjustable ladder bars Bottom hole lowest front heim end setting Right bar - slight preload “5 #150 (?) lbs - springs with spring jacks Stock Mount: 28 year old Koni single adjustable set at 1 turn tight from lightest setting=Issue(?) Pinion angle 2 degrees negative MT 10.5w x 28 slicks with tubes at 14 pds cold - best runs Thanks Guys, Craig |
#12 |
Liked 226 Times in 137 Posts
Try tightening the pull a part on rear shocks.
#13 |
Happy Thanksgiving to all you guys and appreciate all your support and technical help.
Take care, Craig |
#14 |
Liked 702 Times in 203 Posts
Check your Koni shocks. After about 5 or 6 years and my car started acting up on launch. I found one of the Koni shocks was almost froze up. These were single adjustable and no setting adjustment would help. I ordered new Aftco double adjustable and the car came back with consistency and better 60’ times.
Mike 7570 A/SA |
#15 |
Liked 126 Times in 61 Posts
What is the left and right rear wheel weight?
