#21 |
Liked 282 Times in 103 Posts
It's been quite a few years since I tried Goodyear radials.
From what I remember, they may have been a little faster,but I had more inconsistency. Everyone has their own opinions,but in my opinion, the Hoosiers are tough to beat. |
#22 |
Liked 10,820 Times in 2,249 Posts
When we were at a tire test we did two back to back tire tests, within a time window and the Goodyear’s on my Cuda were quicker and faster than the Hoosier Radial.
For me besides the great longevity is the ease of the rubber removal from the rear fenders. |
#23 |
Liked 431 Times in 224 Posts
You need Daryl to hook you up with some of those mud flaps.
S/ST 51 S/C 53 |
#24 |
I tried a significantly shorter burnout this morning at World Finals,
But the car exploded the tires immediately. Second pass went back to regular burn out and no problem. 18 PSI's both passes.
#25 | |
Liked 348 Times in 79 Posts
Can you elaborate?
Pat Clemente #1427 B/S |
#26 |
No mud flaps for me it’s to much aero drag. I loose it or gain it .001 of second at a time.
#27 |
Liked 130 Times in 42 Posts
Radials need to be dead hooked with even then increasing pressure right off the hit to work consistently. Basically just like an automatic car leaves. If your car pounds the bias tires hard to make it leave it may not be able to hook radials. Good shocks, sorted suspension and data logging go a long ways.
https://photos.app.goo.gl/mNJHBABXRNpW43cYA |
#28 |
Liked 652 Times in 184 Posts
When did you switch to a Metric 200
![]() Bad to the bone !!!
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#29 |
#30 | |
Liked 1,840 Times in 428 Posts
Car leaves perfect
james perrone 1290 STK |
