Old 11-11-2022, 07:12 PM   #31
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Default Re: Radial tires
Originally Posted by James Perrone View Post
Are you running a radials in the video?
Car leaves perfect
Yes sir
Troy Henderson is offline   Reply With Quote
Old 11-12-2022, 10:53 AM   #32
James Perrone
Liked 1,841 Times in 428 Posts
Troy you must be the only guy running them
It’s has to be faster.
It’s been said a radial tire could be 1 tenths faster. Than a bias ply
Good job
james perrone 1290 STK
Old 11-13-2022, 11:53 AM   #33
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Originally Posted by Troy Henderson View Post
Radials need to be dead hooked with even then increasing pressure right off the hit to work consistently. Basically just like an automatic car leaves. If your car pounds the bias tires hard to make it leave it may not be able to hook radials. Good shocks, sorted suspension and data logging go a long ways.
https://photos.app.goo.gl/mNJHBABXRNpW43cYA
Whos rear shocks do you use? Car leaves PERFECT
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 11-13-2022, 03:17 PM   #34
4284spd
4284spd's Avatar
Good job
Their is quite a few stick cars running them. Markus Svennson was testing them back in 2019.
94883672_116236470064783_6239002913033682944_o_116 236463398117 by Bob Smith, on Flickr
Bob Smith
Old 11-13-2022, 10:02 PM   #35
Troy Henderson
Fast shocks
Old 11-18-2022, 12:11 AM   #36
Doug Domm
Liked 84 Times in 21 Posts
What rpm difference is there at the top end between bias and radial with the same rollout for each?
Doug Domm is offline   Reply With Quote
Old 11-18-2022, 07:54 AM   #37
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
150 to 200
