Old 11-08-2022, 12:46 PM   #11
CraigG
Liked 8 Times in 7 Posts
Default Re: A Ladder Bar Hole Tuning/Adjustment
72 GTO.
Car launches straight, carries the wheels But now has a traction issue:
Initial hit and spins recovers 10 feet out with loss of .08 to .1 at 60 foot with 3500 launch on 2 step on 5000 convertor
New best with a 6.41 at 105.5 and later spun at 106.
That was an improvement of over 4 mph when I ran a 6.58 at 101.8 from a carb tune, slight port match and a change from 3.73's to 4.11.
Still launching at 3,500 - 2-step with 5,000 still to grab.
Turbo 400 4.11 Pro gears with MT 10.5w x 28 slicks
Front suspension:
QA1 Pro Coil Double Adjustable GM coil over conversion system with 350 # springs
Adjusted to 90/10 settings
Low friction control arm bushings and ball joints
Total Race Weight 3440
Front weight 1860
Rear weight 1580
Percentage Basis Front to rear 55% to 45%
Rear suspension:
Full length Competition engineering adjustable ladder bars
Bottom hole lowest front heim end setting
Right bar - slight preload
“5 #150 (?) lbs - springs with spring jacks
Stock Mount: 28 year old Koni single adjustable set at 1 turn tight from lightest setting=Issue(?)
Pinion angle 2 degrees negative
MT 10.5w x 28 slicks with tubes at 14 pds cold - best runs
Thanks Guys, Craig
CraigG is offline   Reply With Quote
Old 11-08-2022, 02:07 PM   #12
Ralph A Powell
Liked 225 Times in 136 Posts
Try tightening the pull a part on rear shocks.
Old 11-24-2022, 03:07 PM   #13
CraigG
Happy Thanksgiving to all you guys and appreciate all your support and technical help.
Take care, Craig
Old 11-25-2022, 12:41 AM   #14
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Check your Koni shocks. After about 5 or 6 years and my car started acting up on launch. I found one of the Koni shocks was almost froze up. These were single adjustable and no setting adjustment would help. I ordered new Aftco double adjustable and the car came back with consistency and better 60’ times.
Mike 7570 A/SA
Old 11-25-2022, 08:12 AM   #15
SGSST109E
Liked 126 Times in 61 Posts
What is the left and right rear wheel weight?
SGSST109E is offline   Reply With Quote
