#11 | |
Liked 83 Times in 32 Posts
if a 69 engine is in a 72 car |
#12 |
Liked 19 Times in 17 Posts
Tom, I believe GT/A starts at 6.00 and go 1/2 break all way to GT/Q at 14.00. 6th
#13 | |
Liked 920 Times in 259 Posts
Thanks. |
#14 | |
Liked 327 Times in 121 Posts
#15 | |
Liked 1,001 Times in 276 Posts
Duane Hoven 1342 SS/GT |
#16 |
Liked 497 Times in 50 Posts
Need to watch Lonnie's post on NHRA with coverage of the PRI show - day 1 @ 9:00 am. Makes interesting point that they realize people will be switching back and forth to "hide" from competitors with specific engine families and made the statement that they "may" find themselves staying in GT for the year. How that comes about who will know.
#17 | |
Liked 535 Times in 86 Posts
#18 |
68-71 have the same piston, deck height, valve size and head CCs.
#19 |
Liked 37 Times in 7 Posts
I wonder if they are singling out GT with enforcement of rules or will they enforce all class rules in Super Stock Eliminator???
For example a Modified car that is required to run 2 carbs for a specific class but is only using one. Will this still be allowed or will it be corrected??? |
#20 | |
Liked 1,436 Times in 299 Posts
I think if they did raise the quota just enough to be above the fields instead of defaulting to all run. Too much ladder playing because there is no fear of not qualifying. Why not make the minimum field 64 and let 80 in ? Or if they want a lower quota, make the field smaller, I realize some say that it isn’t fair etc. I would put it this way. Don’t sign up for a National event if you don’t want to try and actually qualify. There are many points meets to race in. There are some that are full fields plus and that means some don’t get in. We all seem to be able to survive when that happens. I think also they should consider something such as more points for a heads up win and or more points for better qualifying or a record. Just little nuances that would drive racers to performance. Maybe the SS category indexes should be lowered to reduce the number of stockers that can easily cross over with no mods and easily qualify for the SS field. If we care about SS vs GT, why not look at the easy path to SS by many stockers. Seems odd to push the GT SS deal without looking at that. The GT rule change just reduces the places to hide. Not for all, for some. I realize we can’t afford it to become comp. Heck comp racers can’t afford comp, so it has to be a balance. I feel like NHRA has been in support of policies that don’t require them to do the job that truly defines their existence. Anytime you have rules, you need teams to follow up. NHRA has no succession or sustainability plan for their tech dept. The masters level tech personnel are aging out and retiring. If they don’t make some effort to help that, they will not be relevant.
James Schaechter 3163 STK Last edited by james schaechter; 12-11-2022 at 04:12 PM. |
