Liked 68 Times in 22 Posts
Anybody ever switched from 94 inch rollout to 92 inch tires rear tires? How much rpm change did you notice? Was it a good change or bad change. Any et change? My combo is LT1.
Liked 529 Times in 107 Posts
I do occasionally, 92.5" to 94" Hoosiers. About 150 RPM higher with the shorter tires.
Jim Kaekel 3836 STK |
Liked 733 Times in 384 Posts
Liked 216 Times in 77 Posts
I have a LT1 car. When I originally built it I thought I wanted the biggest tire I could fit. So I put the 94” on it. I’ve since been told I should have the 92.5” with my 4.88 rear gear. So I’m switching.
Liked 7,918 Times in 1,515 Posts
Kdw, I am sure that the majority of class racers have tried both the 92 and 94 inch tires. The rpm difference will be 150-200 …As far as ET , there are so many variables from car to car…..is your first gear a 2.52,2.75,2.85,2.91 ??? The same holds true for rear end gear …Weight of car could also determine what tire it likes. It’s something you just have to try at the track …
Liked 80 Times in 28 Posts
have changed 92" to 94" many times, on two stockers, I and J auto, adds up to 200 rpm in the traps with 4.86 gear. Glen H 1257
Liked 57 Times in 24 Posts
Hoosier Rep told me a rule of thumb is 100 rpm for every
Inch of roll out. So 92 - 94 2 inch difference 200 rpm Looks like from the other posts he was correct |
