#11 |
Liked 7,683 Times in 1,731 Posts
OH YEAH! And the Choir Boys in Stock Eliminator won't manipulate that! Just look at the mess in Comp!
#12 |
Liked 282 Times in 103 Posts
My combo is rated from the factory at 365.
I would be in favor of treating my 365 factor the same as this one: Mopar 426 365 291 295 1964 |
#13 |
Liked 309 Times in 118 Posts
Would you then be in favor of running a manifold from an Olds that came on late 50s engines along with an AFB that flows 575 cfm in place of your QJ that flows 800 cfm. Would you give up the valve to piston clearance and long stroke that allows you so much more cam than the 426 SW can run.
#14 | |
BTW,I don't get the 800.And it was checked at St Louis by tech. Gotcha. |
#15 |
They bring a flow bench to tear down, never saw that.
#16 | |
Liked 274 Times in 143 Posts
For what it's worth, I have a '65 Coronet 426 SW car, and have had no issue finding those intakes or heads that they were originally equipped with. |
#17 | |
https://www.bonanza.com/listings/196...Date/842193838 |
#18 |
Liked 75 Times in 28 Posts
The Mopar's have always been at a disadvantage. We are stuck running 50 and 60 year old intakes. They make aftermarket heads but good luck getting them. Very little to no aftermarket blocks or cranks.
I guess we'll struggle through..... ![]() |
#19 | |
At least the FFFord Racers don't whine.
#20 |
Easy there Billy man, I'm just rattling your chain.
But you have to be honest, the Mopar folks have the least amount of parts to choose from. When you go faster than 75 mph, it takes some good parts and pieces. Have fun and may the force be with you. |
