Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 10-26-2020, 09:35 PM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: 4 foot LED shop lights
I converted my shop at home 2 years ago to 8' twin V strip 270 degree tubes . the difference in light and electric consumption is tremendous . I am saving nearly 20% on my electric bill since switching.
I just converted 16 2 x 4 4 tube fixtures in the building I moved my race shop to after the flood .
I only used 2 tubes in each fixture and the light output is tremendous for a 14' ceiling.
Old 10-27-2020, 08:40 AM   #12
DIAPERMAN
Liked 21 Times in 6 Posts
I just bought a 24 inch by 24 inch led high bay light at Rural King $59 on sale .It replaced a 6 T8 light and it is probably 4 times as bright
DIAPERMAN is offline   Reply With Quote
Old 12-05-2020, 11:23 AM   #13
Signman
Liked 269 Times in 99 Posts
Installed Installed 7 250w LED High Bay Fixture similar to what Sean suggested. They provide excellent light. The negatives are the brightness which gets your attention to look up with the result being like welding flash but after a while the attraction stops. The other is the color temp which is up there 6k - 6.5k which is "daylight" where "cool white" about 5k is more comfortable. Daylight has been widely used in industrial, laboratory, and surgical settings as well as signage. Less power consumption and more light is worth it.
Old 12-16-2020, 02:54 PM   #14
Rod Greene
Liked 242 Times in 81 Posts
OK looking at 8ft LED tubes need some opinions 5000K OR 6000K? 65W OR 90W?
Cold weather has hit and the fluorescents are dying. 30 x 60 shop 20ft ceiling currently 8 2 tube fixtures.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 12-27-2020, 03:28 PM   #15
voltdr
Liked 100 Times in 51 Posts
[QUOTE=Rod Greene;629969]OK looking at 8ft LED tubes need some opinions 5000K OR 6000K? 65W OR 90W?
Cold weather has hit and the fluorescents are dying. 30 x 60 shop 20ft ceiling currently 8 2 tube fixtures.[/QUOTE
Always use the brightest (color rendition) you can. Stay with anything 6000K or higher and also the highest wattage you can get.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 12-19-2022, 07:52 AM   #16
Damon
Damon's Avatar
Hello. I saw multiple sources, and I can say that if you want to economize money and have good thick lighting, you can try simple LED lights. However, you can opt for the smart ones as you have more control over them in brightness and intensity. I'm using smart LED bulbs from amazon for my home, and I can say that I'm satisfied with the result. The best is that Alexa controls them, so I can even use my voice beside my smartphone. I have them preset at 10 pm to slowly decrease their intensity and change their color to red to prepare myself for sleep, and at every moment, I can turn on and off this preset. You may try them, who knows, maybe you'll like them.
Damon is offline   Reply With Quote
Old 12-19-2022, 08:46 AM   #17
SGSST109E
Liked 126 Times in 61 Posts
When I built my garage 9 years ago 30 x30 with 12 foot high ceilings I put 4 strings of single tube LED's. color was 4500. Great lighting and no shadows.
SGSST109E is offline   Reply With Quote
Old 01-08-2023, 01:59 PM   #18
Kenney Kelley
Liked 72 Times in 36 Posts
Originally Posted by Greg West View Post
Looking for a recommendation on LED shop lights. My building has a 14 foot high white metal ceiling.
Thanks
Greg if you text me at 321-412-5196 I will send you some pictures of how i did my Metal Building Because i don't know how to put them on here.
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 01-08-2023, 06:57 PM   #19
CMcAllister
Liked 928 Times in 263 Posts
Who does LEDs to replace 4' T8 fluorescents that are plug and play?
I have 96 4' tubes on my ceiling and really don't want to fool with all that wiring.. The light is great, but I'm about to use my last spares and am wondering if it would be wise to switch.
CMcAllister is online now   Reply With Quote
Old 01-09-2023, 06:24 AM   #20
SGSST109E
I bought some on Amazon for my house. Just do a search there. Remember the ballast will still consume power if its not eliminated. They use about 10 watts so 48 two bulb fixtures is about 500 watts
