Old 01-09-2023, 07:31 PM   #1
John Beasaw III
Liked 2 Times in 2 Posts
Default SBC header adapter plates
I need help, we have a 68 Camaro bracket car with brodix heads. They have stahl pattern for the header flange. The current headers are shot and the closest replacement header doesn't fit dads budget.
Is there a adapter plate from stahl to oem pattern?
Thanks,
John Beasaw
John Beasaw III is offline   Reply With Quote
Old 01-09-2023, 08:43 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: SBC header adapter plates
would the Moroso Header flange kit 67650 not work ?
prostockpete1 is offline   Reply With Quote
Old 01-10-2023, 08:43 AM   #3
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
I have a pair of Stahl plates,maybe you could use them in reverse?
Text me for a pic 1-613-286-5760
Dom
chopperloco is offline   Reply With Quote
Old 01-10-2023, 06:29 PM   #4
DanBar
DanBar's Avatar
Liked 12 Times in 6 Posts
If the Brodix heads are spread port on the two center exhaust ports you can not go to std exhaust flange headers. You can maybe make them fit but the tube to port alignment is way off. Have you checked Schoenfeild headers?
DanBar is offline   Reply With Quote
Old 01-10-2023, 06:54 PM   #5
Billy Nees
Liked 7,925 Times in 1,760 Posts
Have you called ACP? The old Stahl?
Billy Nees 1188 STK, SS
Old 01-10-2023, 07:13 PM   #6
John Beasaw III
The brodix head may be the bigger issue, i will be looking into that. ACP does offer a header but a bit too pricey.
Thanks!
John
Old 01-10-2023, 09:24 PM   #7
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
As DanBar said above, check Schoenfeld Headers. You can order a standard header and specify any bolt pattern flange they have (within Reason). It solved a similar problem I had with a set of heads.
https://www.schoenfeldheaders.com/
Larry Merk
Larry Merk is offline   Reply With Quote
