Old 02-13-2023, 11:50 AM   #1
Liked 10,837 Times in 2,252 Posts
Default 1986 Chevy C10 Race Truck
Number one qualifier at the 40th, 50th, 60th US Nationals.
A 4.3 comes with it even fire
Billy Lynn metric 200
Turbo Action converter
Step headers
Roll bar
Frame boxed
CalTracks bars and springs
Weld wheels
Truck has MoPAR bolt pattern. Stud placement can be moved to Chevy spacing
12 bolt 69 Chevelle rear with spool and Mark Williams axles with braces
MSD box
Tach and gages
Fuel cell 5gal
Aero Space brakes
3 Qt accumulator
Master disconnect
Line lock
GoatHead for Raymond King
Dropped spindles
MSD distributor
Overheard Painless wiring switch panel
Mark Williams quick disconnect steering wheel
MSD Two Step
Good dash and door panels
Drive shaft with Mark Williams yokes and 1320 joints
Factory single core radiator aluminum and plastic radiator
Mallory fuel pump
Fuel filters before and after pump
Bed cover
Chiller connections
OEM owners manual
Rear wheels 15 X 10
Rear brakes are drum with aluminum drums
Pressure regulator with fuel sample valve
MSD coil
Starter bump button on fire wall to adjust valves
Clock shows 93351 miles
We have the title somewhere.
It’s a good piece that has been climate kept since 1993
$11,000
Cell 270 994 4004
Last edited by Larry Hill; 02-14-2023 at 11:02 AM. Reason: Add details, add phone number
Old 02-13-2023, 03:34 PM   #2
Woodfin
Liked 288 Times in 109 Posts
Default Re: 1986 Chevy C10 Race Truck
Would it be available less engine and trans? If so, what is that price?
Old 02-13-2023, 07:21 PM   #3
The engine is better than just an index runner but no demand. $10,500
Old 02-13-2023, 07:29 PM   #4
Only two rust spot less than two inches long at the bottom rear of the door opening. It’s where all of that model has a slight problem.
Old 02-13-2023, 08:15 PM   #5
Double post my fault
Old 02-18-2023, 05:43 PM   #6
leon philpot
Liked 2 Times in 2 Posts
what class & index. what eng. carb or inj.
txt to 972 571-1006
leon philpot is offline   Reply With Quote
Old 02-18-2023, 08:37 PM   #7
262V6 wt. break18.15
305 v8 wt. break 18.48
350 v8 wt. break 16.63
Only C10 listed 1986. FI was 1987
I Hope this helps
Mike, the hood is a documented replacement that NHRA says is wrong. So if the rule book is followed in Stock the Non OEM spun aluminum carb base plates are wrong " non stock base plates prohibited"
Last edited by Larry Hill; 02-19-2023 at 01:25 PM. Reason: to keep from bumping the ad
Old 02-19-2023, 01:20 AM   #8
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
I for one think it would be WAY COOL if you kept it and installed the 305 v-8. With Pat C ‘s help I believe you can be Numero UNO at the 70th running of the US Nats …..and with a LEGAL hood ……
