Old 04-08-2010, 05:09 PM   #21
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Jerico tranmission
Beware of the Nascar trans. They have a harder gear set and will not hold up to shock, like a dragrace trans. The G-Force I bought a couple of years ago was a trade-in. They put all new parts in and re-gear it to what you ask. Mine even came with a magnet already installed in the input shaft for data aquisition. This is used for calculating clutch slippage.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-08-2010, 07:52 PM   #22
hemidup
Originally Posted by Bill Belden View Post
Jerico and Advanced Clutch, only way to go
Thanks for the tip. I'll definatly look into it.
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 04-11-2010, 11:20 AM   #23
EdgarTurbo
Smile Re: Jerico tranmission
Originally Posted by tj310 View Post
Liberty web site says twin countershaft "delio" legal for SS . Twin countershaft does not equal clutchless. Split or individual gear engage disengage = clutchless..IMHO..Thanx Trevor
First off, excuse my sarcasm, but you did not answer my quesion. I saw that one of the options on the new CJ's is the liberty transmission and I was planning to get the same one with different gears off course, I'm running NA and I was checking in the website for liberty transmission 5 speed and the price was 4995.00 and for the jerico tranny was 5500.00 I mean don't give me wrong quality transmissions worth the money but anything I can save means more beer for me,
EdgarTurbo is offline   Reply With Quote
Old 04-11-2010, 06:43 PM   #24
tj310
Liberty sells more than one trans. If you want an answer to a specific question your probably best to start a new thread. ...Thanx Trevor
Old 04-12-2010, 12:39 PM   #25
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Bill, you have a PM.
Dave Turner
SS/GT #1153
Old 04-12-2010, 05:51 PM   #26
EdgarTurbo
OK, thanks Trevor...
Old 04-12-2010, 06:48 PM   #27
Bill Belden
Bill Belden's Avatar
Dave, you have a PM
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 02-19-2023, 10:18 AM   #28
Weekiman
More skilled and experienced then myself but I'm kind of surprised he grinds hard going into reverse and doesn't let the trans spin down for a second or three and then he clunks going into first while still rolling. After coming out of reverse it should go into first like butter even without making a complete stop.
Weekiman is offline   Reply With Quote
Old 02-20-2023, 05:16 PM   #29
Adger Smith
Liked 880 Times in 311 Posts
"Drooze"
Why a aftermarket Transmission?
Just look at the internals parts.
The gear strength and the built in durability.
Adger Smith (Former SS)
Old 02-20-2023, 06:23 PM   #30
Jim Caughlin
Liked 805 Times in 245 Posts
[QUOTE=Chris "drooze" Wertman;180776]Jerry, Called GForce today, theyve got some "used" refurbed units that are "nascar" 4 speed "clutch assisted" units for 2700 with shifter your choice Zgate or H
Apparently something changed in Nascar so they got all their leases back but its the same as the Drag, they said they can do any ratio combo on these.
Sounds like a good deal.....(only on 4's)
Can be shifted without a clutch just has momentary "neutral" while it does as opposed to the twin shaft delio....that always transmits power but that is called a clutchless, technically it wouldnt be legal from the way I read the rules, but the "clutch assisted" would be ? Is this "correct" ?
A lot of strange info on this thread. First off, the difference between a clutch assisted and a clutchless is the result of a split slider, the trans is actually in two gears at once when shifted but because of the speed of the gears, it pops out of the one gear as soon as the other is engaged. Regarding, shifting a clutch assisted trans without the clutch, nothing is needed as long as you have a faceplate type trans, you just reef on the shifter and it will engage the next gear. I have raced both clutch assisted (without the clutch) and clutchless, no big deal either way. In Stock where clutchless is not allowed, pretty much everyone is shifting without the clutch, this has been done for quite some time with no problems.
Jim Caughlin is offline   Reply With Quote
