#21 | |
My post was a statement of my opinion. Here is one more opinion---Maybe they just used common sense? SO we cannot used 60's technology on a 60's head? I believe NHRA IS trying to EVEN THE FIELD, just like you want. Toss the cheaters. But here is the real question Jim. Why do you need to know the spec's? If you cannot modify a head, why would you need a spec? |
#22 | |
As regards to cylinder heads, I can take a pair of cylinder heads, do a competition valve job under the old valve rules and get a specifc volume number...if I take the same pair of heads, put new valves consistent to the new valve rule, I will get a different volume number...these are the facts and those that build engines know this takes place. I could take the heads and surface the intake or exhaust side to get the proper volume numbers...but...which volume numbers I use for a basis for Stock class? Do you see my point? This does not have anything to do with altering cylinder heads with acid or porting...it is just based on the new valve rule. ...and by the way, I am not condoning cheating...these are the facts. Also, the numbers will vary based on the cylinder head design and the valve size. |
#23 | |
Yes, I do see your point. But do we really know that NHRA does not have spec's? Spec's that they aquired from virgin heads? They have spec's for wheelbase, for example. They are not published, but they have spec's. |
#24 |
#25 |
Sometimes even the rule book means nothing. Not trying to change the subject here. But it clearly states that you can only protest a competitor before race day, a friend of mine was protested ON race day and had to tear down. There was no way he could have gotten his car back together for 1st round. Glendora and some of those wizards make it up as we go, again no consistency. I would guess that most racers don't even know the volume of the runners in stock because there is no rule, no listing for each head/engine combo, no + or - , no percentage + or -, so why would anyone care. Castings are castings and each one will be different.
Chuck Beach 3340 STK |
#26 | |
#27 |
Liked 209 Times in 46 Posts
I believe wheelbase specs are in the classification guide on the left hand side of the page.Heads can vary by 2-3 cc's during production. I have found this on many of the crate motor heads that are new from the factory. I know most hate crate motors, but if this is happening now, imagine what it was 30 years ago at the foundry with less sophisticated mfg procedures. Just my .01 worth. Spent the other penny on gas lol.
Mark |
#28 | |
#29 |
Guys:
I have a CNC cylinder head business and have seen variances that you wouldn't believe. The newer aluminum heads don't vary nearly as much as cast iron but they do vary alot. I use to run a 428 Cobra Jet Mustang (many years ago) and have seen those heads vary as much as 6-9 ccs. S.E. |
#30 | |
So, by your own admission, SS spec's (for the most part) are to big to use for a stock head---Correct? So when a 283 head pours 10% more than the SS spec, how do you defend that? How can you justify that big of a runner? Surely, you don't expect me to buy into the new valve rule as being the cause? |
