Old 03-02-2023, 06:36 PM   #11
Liked 5,120 Times in 1,951 Posts
Default Re: Help needed with custom leaf spring build
Originally Posted by Woodfin View Post
Now, back to my original question, if someone with a Camaro or Nova could give the me the front and rear spring eye to ground dimensions it would let me see if I am in the ball park with my design.
I think you might want the following:
Camaro or Nova sitting with jackstands under the housing and the rocker panel level with the floor.
Then you'll want all three measurements, including the axle center line to the floor, for comparison purposes.
The Camaro, Nova, and Chevy II , all had the axle at the same height as the top of the rocker panel (the bottom of the door). The spring eye bolt is very close to the flange at the bottom of the rocker panel
Lots of those cars are higher now though, for tire clearance, etc.
Yes, I've air chiselled out quite a few of them ;-)
Old 03-03-2023, 07:56 PM   #12
Woodfin
Liked 274 Times in 105 Posts
Thanks to each of you for the feedback. After pondering and measuring I have decided to install a 32" ladder bar. This can be done with a minimum amount of cutting and modifying of the body and frame. It will allow a 29.5 x 10.5W tire which will handled the power and performance I have planned.
